Temperature & Acoustics / Power Consumption Temperature AnalysisFor all temperature testing, the cards were placed on an open test bench with a single 120mm 1200RPM fan placed ~8” away from the heatsink. The ambient temperature was kept at a constant 22°C (+/- 0.5°C). If the ambient temperatures rose above 23°C at any time throughout the test, all benchmarking was stopped. For this test we use the 3DMark Batch Size test at its highest triangle count with 4xAA and 16xAF enabled and looped it for one hour to determine the peak load temperature as measured by GPU-Z. For Idle tests, we let the system idle at the Windows 7 desktop for 15 minutes and recorded the peak temperature. ![]() The Lightning’s Twin Froze IV heatsink once again tops the charts with its incredible ability to cool the GTX 680’s core. The result is higher average clock speeds than the competitor from ASUS which is likely why we were seeing MSI’s card pull ahead in certain tests. Acoustical TestingWhat you see below are the baseline idle dB(A) results attained for a relatively quiet open-case system (specs are in the Methodology section) sans GPU along with the attained results for each individual card in idle and load scenarios. The meter we use has been calibrated and is placed at seated ear-level exactly 12” away from the GPU’s fan. For the load scenarios, a loop of Unigine Heave 2.5 is used in order to generate a constant load on the GPU(s) over the course of 20 minutes. ![]() Along with creating a heatsink that allows for low temperatures, MSI has also kept this card’s acoustical profile under strict control. The difference between it and ASUS’ TOP edition won’t be noticeable and there’s just no way you’ll hear it over case fans or the sounds of gaming. System Power ConsumptionFor this test we hooked up our power supply to a UPM power meter that will log the power consumption of the whole system twice every second. In order to stress the GPU as much as possible we once again use the Batch Render test in 3DMark06 and let it run for 30 minutes to determine the peak power consumption while letting the card sit at a stable Windows desktop for 30 minutes to determine the peak idle power consumption. We have also included several other tests as well. Please note that after extensive testing, we have found that simply plugging in a power meter to a wall outlet or UPS will NOT give you accurate power consumption numbers due to slight changes in the input voltage. Thus we use a Tripp-Lite 1800W line conditioner between the 120V outlet and the power meter. ![]() With upgraded components and low temperature, it shouldn’t come as a surprise that MSI’s Lightning doesn’t consume all that much more power than the reference design. However, take note that once its LN2 BIOS is enabled, power consumption will increase substantially. | ||||
