Quantcast
NVIDIA GeForce GTX 670 2GB Review
Author: SKYMTL
Date: May 8, 2012
Product Name: GeForce GTX 670
Share |
A Closer Look at the GTX 670
The GTX 670ís exterior design holds the typical historical hallmarks of an NVIDIA graphics card. It has a predominantly black heatsink shroud with a few touches of green to ensure everyone knows it is part of the GeForce lineup. In terms of length, the GTX 670 is also quite short at 9 ĹĒ but thatís only half the story with this card, but weíll leave the answer to that mystery for a bit later in this section. For now, weíll give you a hint: it has something to do with the oddball location of the dual 6-pin power connectors.
NVIDIA has made a bit of a departure from their typical designs by giving the reference GTX 670 a somewhat aggressive styling with a corrugated heatsink cover but it still retains the typical blower-style fan setup. The cardís side uses the GeForce branding weíve previously seen on the GTX 680 and GTX 690 but this time around, it isnít lit.
We should also mention that even though this is NVIDIAís reference exterior design, very few of their board partners will be using it. Expect the vast majority of launch day boards to come with custom designs.
The GTX 670ís connector layout doesnít differ from the GTX 680ís by one iota. This card is still compatible with dual and tri SLI but won't run in quad mode. The backplate connectors consist of two dual link DVI outputs, one full sized HDMI 1.4 output and a single DisplayPort. As with the GTX 680, it is compatible with NVIDIA Surround and has the capability to output a fourth signal to an accessory display.
Shock was the only way to describe our emotions when we first saw the GTX 670ís underside. While the heatsink shroud extends its length to 9.5Ē, the actual PCB itself reaches a mere 6 ĺĒ, or roughly as long as most entry level cards. The extra plastic section added onto the card houses the fan as well as a small air baffle to direct airflow towards the internal heatsink. Supposedly, board partners will be releasing single slot versions soon after launch.
Some of you are probably wondering why NVIDIA didnít just use with a centrally-mounted axial fan like the one found on the GTX 560 Ti. Unfortunately, the answer isnít a simple one. The GTX 670ís core may be efficient but it still produces up to 170W of heat and most users donít want that being dumped back into their case. In addition, as a matter of perception we all subliminally associate rear exhaust-style setups with higher end products so weíd hazard a guess that NVIDIA wanted that association to remain here.
Even with its heatsink shroud in place, the GTX 670 is the shortest 600-series card NVIDIA has released to date. However, once a card is shorter than a standard ATX motherboard, it really doesnít make all that much of a difference for most users.
Latest Reviews in Video Cards
March 8, 2017
The GTX 1080 Ti has finally arrived! NVIDIA claims its performance is faster than the TITAN X but will our benchmarks confirm that? In a word, YES!...
February 28, 2017
NVIDIA just announced their upcoming GTX 1080 Ti and it is billed as the fastest graphics card on the planet...but it'll cost you....
December 5, 2016
More than four months after the launch of NVIDIA's GTX 1060, we take another look at its performance against AMD's RX 480 8GB in more than a dozen games. The results of this one may surprise you........
