Eldonko
BIOS Rundown p.2
BIOS Rundown
Moving over one more tab to the Main tab we have system information on the BIOS version, CPU and memory as well as the system time and date. In the Advanced tab there are a number of configuration subscreens for CPU, PCH, SATA, System Agent, USB, Onboard Devices, APM, and Network Stack. At the top of the page, the board lighting can be disabled if desired.
The CPU Configuration page contains detailed information on the CPU installed as well as settings for Hyper Threading and active cores. At the bottom of CPU Configuration, there is a subpage titled CPU Power Management Configuration. Here Speedstep, Turbo, and C-State settings are found.
The next two subpages are PCH Configuration and SATA Configuration. These pages are fairly straightforward and contain settings for the chipset and SATA drives.
The last notable subsection of the Advanced tab is the System Agent Configuration page. It is rather buried in subpages but under System Agent there is a Grapohics Configuration page on which settings for the iGPU are found. The iGPU will be disabled by default so to use it, iGPU Multi Monitor must be enabled. To set the iGPU as the primary display set Primary Display to iGPU and remember to connect your monitor to the board’s HDMI port or DisplayPort once you reboot.
The Monitor section contains the system temperature/power status, and adjustable fan settings. Fan speeds are customizable based on a number of settings and there are profiles included in the BIOS. The Boot tab contains boot priority options and POST options. Here you can also change the default BIOS mode from EZ to Advanced and change boot priorities.
Moving over to the Tools tab there are several useful tools available including DRAM SPD Information, EZ Flash 2, OC Profiles, and Go Button file. DRAM SPD Information shows all installed memory with subsections showing SPD and ASUS OC Profiles allow for saving customized OC Profiles suited for different situations. Since the GENE does not have a dual BIOS, keep in mind that if you flash your BIOS your profiles are gone.
Last but not least we have EZ Flash 2 and the Go Button File. EZ Flash 2 is used for flashing the board’s BIOS from a in a safe and easy manner and the Go Button file is where you set up you Go Button settings for instant loading by pressing the GENE’s Go Button near the ProbeIt area.
BIOS Rundown
