Quantcast
Get Adobe Flash player
Gigabyte HD 7950 WindForce & MSI HD 7950 Twin Frozr III Review
Author: SKYMTL
Date: April 18, 2012
Product Name: HD 7950 Windforce 3X / Twin Frozr III
Part Number: GV-R795WF3-3GD / R7950 TWIN FROZRIII OC
Warranty: 3 Years (GB and MSI)
Share |
Gigabyte HD 7950 Windforce 3X OC
Gigabyte’s HD 7950 OC is an imposing card which is topped by the massive Windforce 3X heatsink but otherwise, it retains the standard PCB layout. Pricing on this isn’t all that bad either since it only carries a $20 premium over the reference version even though its cooler is supposed to lower temperatures by a significant amount.
Speaking of the heatsink, it really is the star of this show. This particular example uses the same design we saw on the HD 7970 version with a trio of 80mm fans and a vapor chamber which covers the core and memory modules. As with all of the custom coolers these days, the main heatsink is aluminum but in order to increase thermal capacity, Gigabyte has added a number of smaller fin arrays that are attached to the vapor chamber via copper heatpipes. The layout is a novel one since it allows for reduced temperatures without taking up too much vertical space.
Since this large and frankly quite complicated heatsink weighs in at about two pounds and puts significant pressure upon the card’s center point, Gigabyte added an aluminum band along the PCB’s edge to eliminate flexing.
Power connectors on the WindForce 3X retain the reference dual six pin configuration but the PCB uses Gigabyte’s blue colour. This is the direction Gigabyte usually goes with their initial cards. It changes AMD’s HD 7950 layout but incorporates slightly different components which helps keep costs under control.
The output connector selection here is basic at best. Even with single dual link DVI and HDMI 1.4 connectors, this card still isn’t natively compatible with multi monitor solutions since Gigabyte hasn’t included the necessary dongles to convert the WindForce 3X’s two mini DP headers into full sized DisplayPort outputs.
Latest Reviews in Video Cards
May 23, 2013
With the GTX 600-series slightly more than a year old, NVIDIA is now ready to start refreshing their GeForce lineup once again.  The first card out of the gate is their GTX 780, a $649 GK110-based fla...
April 23, 2013
AMD's HD 7990 has been rumored for more than a year but now it's finally here.  With it, we get a pair of Tahiti XT cores, 6GB of memory and an insanely quiet heatsink all wrapped into a $999 card tha...
April 8, 2013
NVIDIA's $170 GTX 650 Ti Boost has quickly become the go-to choice for gamers on a budget and board partners have been quick to jump on board.  In this roundup, we take a look at cards from ASUS, EVGA...
