Quantcast
Patriot Pyro SE 240GB SSD Review
Author: AkG
Date: April 25, 2012
Product Name: Pyro SE 240GB
Part Number: PPSE240GS25SSDR
Warranty: 3 Years
Share |
Read Bandwidth
For this benchmark, HDTach was used. It shows the potential read speed which you are likely to experience with these hard drives. The long test was run to give a slightly more accurate picture. We don’t put much stock in Burst speed readings and thus we no longer included it. The most important number is the Average Speed number. This number will tell you what to expect from a given drive in normal, day to day operations. The higher the average the faster your entire system will seem.
Much like previous ONFi 2 based SF2281 drives, the Patriot Pyro SE provides sequential read performance which is blazing fast.
Write Performance
For this benchmark HD Tune Pro was used. To run the write benchmark on a drive, you must first remove all partitions from that drive and then and only then will it allow you to run this test. Unlike some other benchmarking utilities the HD Tune Pro writes across the full area of the drive, thus it easily shows any weakness a drive may have.
As with the sequential read performance, the average write performance of the Patriot Pyro SE is right where you would expect it to be. It may lag behind high performance drives such as the Vertex 4 and Intel 520, but considering the price disparity between those truly enthusiast grade devices and the Pyro SE, its price to performance ratio is certainly excellent.
Latest Reviews in Storage
March 6, 2018
The Crucial MX500 follows in the footsteps of some of the best SSDs; the MX300 and MX200. But in a very competitive market, can it even compete these days?...
February 25, 2018
It is the FASTEST SSD we've ever tested, providing unbelievable benchmark performance but the Intel Optane SSD 900P also has some very serious limitations....
January 9, 2018
Toshiba has announced the new RC100 NVMe M.2 SSD Series, which targets value-oriented gamers, DIY system builders, and system integrators....
