Quantcast
Intel i7-3770K Ivy Bridge CPU Review
Author: MAC
Date: April 23, 2012
Product Name: i7-3770K
Warranty: 3 Years
Share |
Clock-per-clock: Ivy vs. SB-E vs. SB
Now as we have already discussed, although Intel didn't really do anything drastic to the CPU portion of Ivy Bridge they did do a few small obscure tweaks to the cores, so we are interested in finding out the effect of these changes on the instructions per clock (IPC) and how IVB compares on a clock-per-clock basis with Sandy Bridge and Sandy Bridge-E.
3.5GHz - Ivy Bridge vs. Sandy Bridge-E vs. Sandy Bridge
Now as you can see we clocked all three chips to as close to 3.50GHz as possible and we set identical memory frequencies (DDR3-1600) and timings (8-8-8) for all, although the i7-3820 does retain its quad-channel interface (not really an advantage as we have proven before). We selected a nice mix of applications in order to get a good idea of single and multi-threaded performance.
As you can see, it's good that we kept our expectations low. On average, Ivy Bridge is about 4% faster than the two Sandy Bridge variants on a clock-per-clock basis. Neither the single or multi-threaded performance really stands out, both are about equally improved. 3D modelling and media creation are the areas that see the biggest boost, and although not demonstrated above minimum frame rates while gaming are consistently higher thanks to IVB's super-low latency L3 cache.
Those who were hoping for a giant leap forward performance-wise are obviously going to be disappointed, but keep in mind that Intel has achieved this level of performance with a much smaller TDP than on Sandy Bridge (77W vs. 95W/130W), so it is an impressive feat.
Don't let this clock-per-clock comparison turn you off Ivy Bridge though, because as you will on the following page, one of IVB's strengths is its Turbo Boost implementation.
Latest Reviews in Processors
February 11, 2018
AMD's Raven Ridge is finally here but can the Ryzen 5 2400G and Ryzen 3 2200G really deliver in the performance categories where other APU have failed?...
January 7, 2018
At CES 2018, AMD has detailed their strategy for 2018. That includes second generation Ryzen and Threadripper CPUs, new Zen+ architecture and more....
January 7, 2018
