Quantcast
AMD Radeon HD 7770 & HD 7750 Review
Author: SKYMTL
Date: February 13, 2012
Product Name: HD 7770 / HD 7750
Share |
PowerColor HD 7770 1GB
Simply put, the PowerColor card sent to us retained the reference design, right down to the heatsink installed over the core. It includes a single intake fan as well as a branded shroud that differs a bit from the standard glossy AMD colour scheme but is otherwise bone stock.
The only area in which PowerColor’s card differs from the reference design is their use of a red PCB. Otherwise, everything from output connectors (a mini DP to DP adaptor is included in the box) to fan choice is in line with AMD’s original specifications.
HIS HD 7750 iCooler
Like all of AMD’s board partners, HIS has decided to do away with the lackluster reference cooler and install their own cooling solution. In this case, it is nothing more than a single slot heatsink topped by a basic fan and a clamping system that tends to fall off if manipulated the wrong way.
Other than the “iCooler”, HIS sticks with the standard PCB, clock speeds and video outputs for this card. Don’t expect any adaptors either since the HD 7750 comes with full size HDMI, DisplayPort and DVI connectors.
Latest Reviews in Video Cards
August 14, 2017
After nearly two years of teases, AMD's Vega 64 and Vega 56 have finally arrived. Can these two graphics cards really compete with NVIDIA's Pascal lineup?...
July 30, 2017
AMD has finally revealed almost everything there is to know about RX Vega including its pricing, performance and specifications. Is it a disappointment or everything we were hoping for?...
June 12, 2017
Cramming low power components into ultrabooks is easy. But what NVIDIA has done is shoehorn some serious GPU horsepower into some of the thinnest gaming notebooks around without requiring many sacrifi...
