Quantcast
AMD Radeon HD 7770 & HD 7750 Review
Author: SKYMTL
Date: February 13, 2012
Product Name: HD 7770 / HD 7750
Share |
MSI HD 7770 OC
MSIs OC Edition looks promising at first glance and we have high expectations for its cooling and overclocking potential but clock speeds are quite disappointing. While were used to seeing pre-overclocked cards hitting between 10 and 15 percent above reference spec, MSI has gone ahead with a pathetic 20MHz core overclock on top of the reference cards 1GHz default speed while the memory clocks remain unchanged. This wont make one bit of difference in our charts so if you are looking for how this card performs, look no further than the reference HD 7770.
With a pair of top mounted fans, large heatpipes and an end to end aluminum fin array, this cards heatsink certainly looks impressive. It also causes the fan shroud to extend past the PCBs edge, making the MSI HD 7770 8 long or about more than the reference design.
The backplate on this card sticks to the reference design other than the inclusion of a branded grille area. MSI does however include a mini DisplayPort to Displayport adaptor so three active display outputs are possible provided your monitors support HDMI, DVI and DisplayPort.
XFX HD 7770 Black Edition S Double Dissipation
XFXs HD 7000-series cards have all received custom treatment in one way or another and their HD 7770 doesnt escape this fate. Along with four other versions, the Black Edition S Double Dissipation incorporates a specially engineered heatsink as well as some impressive clock speeds of 1120 / 5200. Since this is also part of XFXs DD lineup, it receives their full Lifetime Warranty provided registration takes place within 30 days of purchase.
The Double Dissipation heatsink is quite extensive for such an efficient card though it doesnt add to the HD 7770s reference length of just over 8. XFX has also equipped it with a small vapor chamber above the core along with a pair of 80mm intake fans.
Along with the logo stamped high airflow bracket, the Black Editions backplate sticks to the reference design but XFX has also included a single HDMI to DVI adaptor.
Latest Reviews in Video Cards
March 8, 2017
The GTX 1080 Ti has finally arrived! NVIDIA claims its performance is faster than the TITAN X but will our benchmarks confirm that? In a word, YES!...
February 28, 2017
NVIDIA just announced their upcoming GTX 1080 Ti and it is billed as the fastest graphics card on the planet...but it'll cost you....
December 5, 2016
More than four months after the launch of NVIDIA's GTX 1060, we take another look at its performance against AMD's RX 480 8GB in more than a dozen games. The results of this one may surprise you........
