Review Contents:
Noctua NT-H1 Pro Grade Thermal Compound Review
by Prof. Dr. Silver     |     March 21, 2008
Noctua NT-H1 Pro Grade Thermal Compound Specifications
From Noctua’s web site:
Noctua’s NT-H1 is a pro-grade TIM solution for enthusiasts who demand both exceptional performance and maximum ease of use: A hybrid compound of different micro-particles allows for minimum thermal resistance, excellent ease of use and outstanding long term stability.
Here are some of the ‘Noctua NT-H1 Pro-Grade Thermal Compound’ product descriptions:
• Excellent performance
• Maximum ease of use & efficient dosage
• Excellent long-term stability(recommended up to three years of usage)
• Not electrically conductive
• Non-corroding
• Suitable for compressor cooling
• Thermal Resistance: Not disclosed by Noctua
• Dielectric Constant@ 1KHz: 4.0
• Dielectric Strength: 1.5 kV/mm
• Specific Gravity: 2.49g / cm3
• Thermal Conductivity: Not disclosed by Noctua
• Poise: 4800
• Color: Dark Gray
• Volume: 1.4ml syringe
• Peak Operating Temperature: -50C to +110C
• Recommended Operating Temperature: -40C to +90C
How Thermal Compound Works
Let’s explain first what TIM (Thermal Interface Material) really is. Thermal Interface Material is a substance designed to take heat from one object and transfer it to another. It could be silicon based, metal based or ceramic based. We’ll use all three different ones today in our tests. It is mostly used in the computer industry for dissipation of heat through a heatsink. CPU’s and GPU’s generate tons of heat and we all know that heat is bad for our computers. So we want the product that is going to help us most in keeping our rigs cool. The workings of TIM are based on a difficult formula that looks like this:
Hold onto your hats folks, this is where it gets complicated.
Thermal conductivity = heat flow rate × distance / (area × temperature difference). In physics, thermal conductivity, "k" is the property of a material that indicates its ability to conduct heat. It is defined as the quantity of heat, "ΔQ", transmitted during time "Δt" through a thickness "L", in a direction normal to a surface of area "A", due to a temperature difference "ΔT", under steady state conditions and when the heat transfer is dependent only on the temperature gradient. (Thanks to Wikipedia.)
Well, that is not the only difficult part. When we're talking TIM, we also have to look at the density, viscosity, thermal resistance and now that Noctua claims that NT-H1 is non-conductive, we also have to look at a new term: Dielectric Constant. Our product has a density/gravity of 2.49 g/cm3 which is explained like this: Density is mass (m) per unit volume (V). To keep it short, Noctua NT-H1 is 2.49 times denser than water. Which is better for the thermal conductivity and thermal resistance. See how it all comes together? Viscosity is explained like this: the measure of the resistance of a fluid to being deformed by either shear stress or extensional stress. In other words: the thickness of a fluid. It is measured in cP (Poise). With Corn syrup being at 1300cP you can now imagine what the Noctua NT-H1 looks like. As for dielectric constant numbers, the lower its value, the less relative static permittivity is has. In Laymen’s terms: It is non-conductive.
Now, let us take the CPU/Heatsink combination for example. These two surfaces are never really flat, meaning that if you put the heatsink on the CPU, there will be AIR in between the two of them. And that is BAD. Air is 8000 times less efficient in conducting heat than your thermal paste. What the thermal paste does is basically fills up the minute gaps, scratches and dents in between the two, so that heat can dissipate faster.
Latest Reviews in Air Cooling
April 30, 2008
Even though some may think that the original Thermaltake Big Typhoon is a relic of days gone by, we have decided to put it to the ultimate test. Can it cool off som...
April 18, 2008
Thermalright is known in many corners of the enthusiast world as the king of cooling. They have launched many innovative products in their history and the latest on...
April 16, 2008
These days, we don't hear too much about aftermarket chipset cooling outside of water cooling circles. Yet, Coolink has been working hard on the sidelines designing...
LinkBacks (?)
LinkBack to this Thread: http://www.hardwarecanucks.com/forum/hardware-canucks-reviews/5134-noctua-nt-h1-pro-grade-thermal-compound-review.html
Posted By Date
Noctua.at - sound-optimised premium components "Designed in Austria"! May 13, 2008
TipidPC.com | The Coolers Thread: CPUs / GPUs / HSFs / Fans: New Products and Reviews May 9, 2008
TipidPC.com | The Coolers Thread: CPUs / GPUs / HSFs / Fans: New Products and Reviews April 30, 2008
Noctua.at - sound-optimised premium components "Designed in Austria"! April 26, 2008
3DCenter.org | 3D-Grafikkarten-Benchmarking, Downloads, News & Reviews April 24, 2008
The blog of Björn Johansson: HardwareCanucks testar kylpastor April 22, 2008
KetZone.com » 775 Socket April 17, 2008
PCSTATS.com - Get The 'Stats and Stay Informed! Hardware Comparsion HQ April 16, 2008
CPU Heatsink Review Round Up | MEGATechNews :: Mega Techie Goodness For the Masses April 13, 2008
[H] Enthusiast - April 3, 2008
Unique CPU coolers & PC Accessories, somuchMORE.biz April 3, 2008
Noctua.at - sound-optimised premium components "Designed in Austria"! March 31, 2008
[H] Enthusiast - March 26, 2008
[OC]ModShop - Noctua NT-H1 Pro Grade Thermal Compound Review March 26, 2008
PC Perspective - The #1 Choice for PC Hardware Reviews and Information March 25, 2008
The breadbox - The Tech Report March 25, 2008
Noctua NT-H1 Pro Grade Thermal Compound Review - Madshrimps Forum Madness March 25, 2008
PCSTATS.com - Get The 'Stats and Stay Informed! Hardware Comparsion HQ March 24, 2008
Noctua NT-H1 Pro Grade Thermal Compound - PCSTATS.com March 24, 2008
[H] Enthusiast - March 24, 2008
Top news stories - The Tech Report March 24, 2008
Techgage - Home March 24, 2008
Top news stories - The Tech Report March 23, 2008
Monday Shortbread - The Tech Report March 23, 2008
[H] Enthusiast - March 23, 2008
TechConnect Magazine - Techconnect Review Round-up 22/3/08 March 23, 2008
[H] Enthusiast - March 22, 2008
[H]ard|OCP - www.hardocp.com March 22, 2008
[H]ard|OCP - www2.hardocp.com March 22, 2008
TechConnect Magazine - Techconnect Review Round-up 22/3/08 March 22, 2008
Blue's News - All the carnage that's fit to post! March 22, 2008
[H]ard|OCP - hardocp.com March 22, 2008
Noctua NT-H1 Pro Grade Thermal Compound March 22, 2008
Viper Lair: Computer Hardware Reviews, Articles and Guides March 22, 2008
Weekend Roundup :: TweakTown March 22, 2008
Noctua NT-H1 Pro Grade Thermal Compound Review - DriverHeaven.net March 21, 2008
iActu - Page 2 March 21, 2008
