Temperature & Acoustics / Power Consumption
Temperature Analysis
For all temperature testing, the cards were placed on an open test bench with a single 120mm 1200RPM fan placed ~8” away from the heatsink. The ambient temperature was kept at a constant 22°C (+/- 0.5°C). If the ambient temperatures rose above 23°C at any time throughout the test, all benchmarking was stopped. For this test we use the 3DMark Batch Size test at its highest triangle count with 4xAA and 16xAF enabled and looped it for one hour to determine the peak load temperature as measured by GPU-Z.
For Idle tests, we let the system idle at the Windows 7 desktop for 15 minutes and recorded the peak temperature.
The Dual Fan heatsink on Sappire’s card allows it to reach some very impressive temperature levels, even the core is overclocked and voltages are increased. Naturally, the higher clock speeds result in elevated temperatures but they are still nowhere near those posted by the reference card.
Acoustical Testing
What you see below are the baseline idle dB(A) results attained for a relatively quiet open-case system (specs are in the Methodology section) sans GPU along with the attained results for each individual card in idle and load scenarios. The meter we use has been calibrated and is placed at seated ear-level exactly 12” away from the GPU’s fan. For the load scenarios, a loop of Unigine Heave 2.5 is used in order to generate a constant load on the GPU(s) over the course of 20 minutes.
In addition to a cool-running core, the amount of noise Sapphire’s Dual Fan puts out is minimal, so much so that when not overclocked it is one of the quietest cards we have tested to date.
When clock speeds are pushed and the custom voltage profile is enabled, the Dual Fan still remains well behaved though there is a significant –yet not overly noticeable- jump in fan speeds. To be honest with you, this is currently one of the best options out there if you are looking for a quiet, high performance graphics card with plenty of overclocking headroom.
System Power Consumption
For this test we hooked up our power supply to a UPM power meter that will log the power consumption of the whole system twice every second. In order to stress the GPU as much as possible we once again use the Batch Render test in 3DMark06 and let it run for 30 minutes to determine the peak power consumption while letting the card sit at a stable Windows desktop for 30 minutes to determine the peak idle power consumption. We have also included several other tests as well.
Please note that after extensive testing, we have found that simply plugging in a power meter to a wall outlet or UPS will NOT give you accurate power consumption numbers due to slight changes in the input voltage. Thus we use a Tripp-Lite 1800W line conditioner between the 120V outlet and the power meter.
This is where things start to go astray. At stock speeds, the low core temperatures and upgraded components increase the Dual Fan’s efficiency when compared to a reference product. That’s the good news. The bad news is that higher voltage, increased clock speeds and the associated jump in temperatures result in a massive power consumption jump.
Granted, if you are looking for the best possible in-game performance efficiency is usually a secondary concern but its best to be aware that pushing a HD 6970 will result in GTX 580-beating power consumption.
