Seagate Barracuda 3TB in RAID 0: Performance Unleashed
Author: Anthony “AkG” Garland
Date: January 21, 2012
Product Name: Barracuda 3TB
Part Number: ST3000DM001
Warranty: 2 Years
Share |
Read Bandwidth
For this benchmark, HDTach was used. It shows the potential read speed which you are likely to experience with these hard drives. The long test was run to give a slightly more accurate picture. We don’t put much stock in Burst speed readings and thus we no longer included it. The most important number is the Average Speed number. This number will tell you what to expect from a given drive in normal, day to day operations. The higher the average the faster your entire system will seem.
As expected the sequential read performance is basically double of that of a single 3TB Barracuda. This has always been a major strong point for RAID 0 and comes as no surprise. With that being said, these numbers are impressive and can easily compete against even 240 - 256GB Solid State Drives.
Write Performance
For this benchmark HD Tune Pro was used. To run the write benchmark on a drive, you must first remove all partitions from that drive and then and only then will it allow you to run this test. Unlike some other benchmarking utilities the HD Tune Pro writes across the full area of the drive, thus it easily shows any weakness a drive may have.
As with the sequential read, the write performance is close to double of what a single 3TB Barracuda can accomplish. This minor variation is in all likelihood due to margin of error and the fact that the second drive was not quiet as fast – on average – as the first Barracuda drive was. The minor variation is neither here nor there and as with sequential read performance does not tell us anything that we were not expecting: namely that sequential performance is always the strong suit of RAID – 0 and these numbers are impressive to say the least.
Latest Reviews in Storage
March 6, 2018
The Crucial MX500 follows in the footsteps of some of the best SSDs; the MX300 and MX200. But in a very competitive market, can it even compete these days?...
February 25, 2018
It is the FASTEST SSD we've ever tested, providing unbelievable benchmark performance but the Intel Optane SSD 900P also has some very serious limitations....
January 9, 2018
Toshiba has announced the new RC100 NVMe M.2 SSD Series, which targets value-oriented gamers, DIY system builders, and system integrators....
