QNAP TS-409 Pro Turbo NAS Review
by AkG     |     March 10, 2008
Disaster Recovery
Testing Methodology
While a NAS appliance should be easy to use and have decent performance there is one area where it absolutely has to be 100% reliable and that is with its ability to recover from a dead hard drive (aka Disaster Recovery). Unfortuntely, in the real world things are rarely as black and white as this and nothing should be taken for granted; especially when precious records are on the line. Even more basic is that while a NAS should always recover from a bad drive, what about its rebuild times? The amount of time it takes for a NAS to rebuild its array is critical since this is a time where it is most vulnerable to catastrophic loss of data. This test can therefore be considered a three part test. The first part is PASS/FAIL and deals with if the RAID array worked and is the array’s data still available and not corrupt when a hard drive “dies”. The second part deals with how the array deals with replacement of the missing hard drive and is also a PASS/FAIL based on if the array will crash or hang during this process. Does it require you to rebuild the array manually by first destroying all data on the array and starting from scratch (which is in our opinion unacceptable performance). The third part (should it pass the first two parts)deals with how long it took for the array to get out of degraded mode and is also a PASS/FAIL. Regardless of performance we will inform you how long it takes but if its rebuild performance is less than 50 gigabytes an hour it is not fast enough to be considered effective.
To this end for each mode that the NAS offers that has disaster recovery, we start by first formatting and then filling them to the maximum capacity available in a given mode. After this was completed and we then verified that the data was indeed stored on the NAS before simulating a catastrophic failure. This failure was accomplished by removing one of the hard drives, while the unit is running (if it supports hot swapping, if it does not we power off the unit and remove the hard drive and then turn the unit back on). We then checked to see if the data was still available. If it is we then replace the “dead” hard drive and observe what the unit does with it. As soon as the hard drive is reinserted we start the timer and keep it running until the NAS informs us that it has finished its rebuild. All tests were run twice. All tests were not performed “one after the other”; rather they took place over a period of a week and were widely spaced out so as to help reduce any possible chances of overloading the array and introducing any non repeatable errors. If for any reason, the array fails a section of the test. The test will be reran, if it fails a second time it will be considered a true FAIL, we will however inform you of any errors we get during testing even if the error did not reoccur.
Test Results
RAID 1:
In RAID 1 all four of the enclosure's hard drives showed as two separate mappable network drives. When one of the hard drives was removed all data was still secure. The only noticeable difference was that the HDD2 Failure light went on. By reinserting the second drive the enclosure immediately started to rebuild its array and did not check to see if the reinsert hard drive data was intact. Rebuild time took nearly 4 hours to complete. Overall, this is good performance for its price range and can be considered a PASS on all 3 sections.
RAID 5:
In RAID 5 all four of the enclosures show as one network drive (however its size was only equal to that of 3 of the hard drives original size). When one of the hard drives was removed all data was still secure. The only noticeable difference was that the HDD4 Failure light went on. By reinserting the second drive the enclosure immediately started to rebuild its array and do not check to see if the reinsert hard drive data was intact. Rebuild time took nearly 5 hours to complete. If at any time during this rebuild process had another hard drive failed the array’s data would have been lost. This is very decent performance considering the amount of processor intensive work involved in creating parity, and should be considered a PASS on all 3 sections.
RAID 5 + online spare:
In RAID 5 all four of the enclosures show as one network drive (just that the size was equal to only two of the hard drives original size). When one of the hard drives was removed all data was still secure. The only noticeable difference was that the HDD3 Failure light went on and the online spare in bay 4 automatically started to show activity as the array automatically rebuilt its array. By reinserting the missing drive the enclosure did nothing with this drive, but did allow us to set it as the “online spare”. By waiting for the array to finish rebuilding I was also given the option of expanding the array. Rebuild time took nearly 5 hours to complete. If at any time during this rebuild process had another hard drive failed the array’s data would have been lost. This was very nice performance and the online spare does offer peace mind, this is a definite PASS on all 3 sections.
RAID 6
In RAID 6 all four of the enclosures show as one network drive (just that the size was equal to only two of the hard drives original size). When one of the hard drives was removed all data was still secure. The only noticeable difference was that the HDD2 Failure light went. By reinserting the second drive the enclosure immediately started to rebuild its array and do not check to see if the reinsert hard drive data was intact. Rebuild time took over 6 hours to complete. If at any time during this rebuild process had another hard drive failed the array’s data would still have been safe. This is good performance in rebuilding and since the array was in no danger during this rebuild time the results are in the excellent category, a definite PASS for all 3 sections.
As you can see not only is this NAS user friendly but your data is safe even when you lose a hard drive. Its rebuild times were decent and in the end this NAS performed it’s most basic and yet most important task without any hiccups.
Latest Reviews in Storage
February 6, 2012
We've been hearing about and anticipating new Intel's Cherryville SSDs for some time now they are finally being released in the guise of the 520 series.  They are built around the same SandForce SF228...
January 23, 2012
Seagate's new Barracuda 3TB is one of the fastest hard drives currently available and it come with plenty of storage space for a reasonable price.   What it can't do is compete on a level performance ...
January 12, 2012
Corsair's Performance 3 256GB SSD showed many enthusiasts that an SSD didn’t need to have “SandForce” in the same sentence as “performance” and that the new Marvell controller was a force to be reckon...
