NVIDIA GeForce GTX 560 Ti 448 Roundup (EVGA, Gigabyte, MSI)
Author: SKYMTL
Date: November 28, 2011
Product Name: GeForce GTX 560 Ti 448
Share |
Gigabyte GTX 560 Ti 448
Part Number: GV-N560448-13I
Warranty: 3 Years from date of manufacture
Price @ Launch: $289 USD
Much like EVGA, Gigabyte has gone for the path less travelled when designing their GTX 560 Ti 448. They have used their Windforce 3X heatsink which is capped by three large (but quiet) 80mm fans and looks slightly awkward perched atop such a short PCB.
While the overall design of this GTX 560 looks like nothing we’ve seen before, its clock speeds stick to the reference speeds and the warranty period is Gigabyte’s usual 3 years. This card’s price however is particularly interesting since it should stick to the $289 “reference” price which could make for a phenomenal value.
The Windforce 3X cooler uses a large copper vapor chamber which also covers the memory modules and a truly impressive looking heatpipe to achieve optimal cooling efficiency. While the heatsink may look familiar, the PCB itself seems to be a custom designed affair that has been tailor made for the GTX 560 Ti 448. It does use Gigabyte’s usual blue but we’re reasonably sure this layout hasn’t been used on a previous card.
The heatsink’s huge size means it sticks out over the PCB’s edge by a good 1.5”, making the Gigabyte GTX 560 Ti 448 the longest card in this roundup at 11.25”. We can also see that unlike the EVGA card, this one adheres to a dual 6-pin power connector layout.
The backplate is a custom design with dual DVI connectors and full sized outputs for HDMI 1.4a and DisplayPort.
Latest Reviews in Video Cards
November 1, 2017
Enough of the endless unboxings, rumors and presumptions! The GTX 1070 Ti is finally here and it's performance results are impressive to say the least!...
August 14, 2017
After nearly two years of teases, AMD's Vega 64 and Vega 56 have finally arrived. Can these two graphics cards really compete with NVIDIA's Pascal lineup?...
July 30, 2017
AMD has finally revealed almost everything there is to know about RX Vega including its pricing, performance and specifications. Is it a disappointment or everything we were hoping for?...
