System Benchmarks: LFE / Photoshop CS4 / x264 HD 4.0 System Benchmarks: LFE / Photoshop CS4 / x264 HD 4.0Lame Front EndLame Front End v1.0 is a single-threaded application, which means that it only utilizes a single processor core. This will obviously limit performance but it will allow us to gauge a processor's single-threaded performance as well as test any turbo feature that it might have. We will be encoding a WAV rip of Santanas Supernatural album and converting it to MP3 using the highest fidelity VBR 0 quality preset. ![]() Photoshop CS4 64-bitFor the image editing portion of this review, we will use Photoshop CS4 in coordination with Driver Heavens Photoshop Benchmark V3, which is an excellent test of CPU power and memory bandwidth. This is a scripted benchmark that individually applies 15 different filters to a 109MB JPEG, and uses Photoshops built-in timing feature to provide a result at each test stage. Then its simply a matter of adding up the 15 results to reach the final figure. ![]() x264 HD Benchmark v4.0 x264x264 HD Benchmark v4.0 x264 Test: MPEG-2 HD 720P Video Clip Conversion to x264 DVD Video Length: 30 Seconds Comparison: FPS of Second Pass x264 is quickly becoming the new codec of choice for encoding a growing number of H.264/MPEG-4 AVC videos. Think of it as the new Divx of HD and you can understand why we felt it critical to include. Tech Arp's recent development of the x264 HD Benchmark takes a 30 second HD video clip and encodes it into the x264 codec with the intention of little to no quality loss. The test is measured using the average frames per second achieved during encoding, which scales with processor speed and efficiency. The benchmark also allows the use of multi-core processors so it gives a very accurate depiction of what to expect when using encoding application on a typical full length video. ![]() | ||||
| Latest Reviews in Processors | |||||||||
