Quantcast
Get Adobe Flash player
Seagate Barracuda 3TB Review; A 1TB / Platter Monster is Unleashed
Author: AkG
Date: October 31, 2011
Product Name: Barracuda 3TB
Part Number: ST3000DM001
Warranty: 2 Years
Share |
Testing Methodology
Testing a drive is not as simple as putting together a bunch of files, dragging them onto folder on the drive in Windows and using a stopwatch to time how long the transfer takes. Rather, there are factors such as read / write speed and data burst speed to take into account. There is also the SATA controller on your motherboard and how well it works with SSDs & HDDs to think about as well. For best results you really need a dedicated hardware RAID controller w/ dedicated RAM for drives to shine. Unfortunately, most people do not have the time, inclination or monetary funds to do this. For this reason our testbed will be a more standard motherboard with no mods or high end gear added to it. This is to help replicate what you the end user’s experience will be like.
Even when the hardware issues are taken care of the software itself will have a negative or positive impact on the results. As with the hardware end of things, to obtain the absolute best results you do need to tweak your OS setup; however, just like with the hardware solution most people are not going to do this. For this reason our standard OS setup is used. However, except for the Vista load test times we have done our best to eliminate this issue by having the drive tested as a secondary drive. With the main drive being a Kingston HyperX 240GB Solid State Drive.
For synthetic tests we used a combination of the ATTO Disk Benchmark, HDTach, HD Tune, Crystal Disk Benchmark, IOMeter, AS-SSD and PCMark 7.
For real world benchmarks we timed how long a single 10GB rar file took to copy to and then from the devices. We also used 10gb of small files (from 100kb to 200MB) with a total 12,000 files in 400 subfolders.
For all testing a Asus P8P67 Deluxe motherboard was used, running Windows 7 64bit Ultimate edition (or Vista for boot time test). All drives were tested using AHCI mode using Intel RST 10 drivers.
All tests were run 4 times and average results are represented.
Processor: Core i5 2500
Motherboard: Asus P8P67 Deluxe
Memory:
8GB Corsair Vengeance "Blue" DDR3 1600
Graphics card: Asus 5550 passive
Hard Drive: 1x Kingston HyperX 240GB, OCZ 480GB RevoDrive3 x2
Power Supply: XFX 850
Latest Reviews in Storage
May 20, 2013
Seagate has begun a complete top to bottom refresh of their hard drive lineup and the Desktop HDD.15 4TB is their latest addition.  This HDD houses impressive amounts of storage space and even though ...
May 11, 2013
mSATA SSD drives are all the rage these days and Intel is now jumping head first into the market with their new 525 Series.  In this review, we take a look at the 120GB and 180GB versions, two drives ...
May 2, 2013
Seagate's so-called "hybrid" solutions have been around for a while, successfully combining the capacity of a hard drive with the speed of an SSD.  Their new SSHD series takes this mantra to the next ...
