Test Setup and Testing Methodology
Our test setup consists of an Intel i7 2600k Sandy Bridge CPU, Gigabyte Z68XP-UD5 motherboard, and a kit of G.Skill memory. Here are a few shots of the setup and hardware:
First we have the whole test bench up and running. As you can see we used watercooling (Apogee XT) for the CPU along with two heatercores. A second GTX 470 was also added for SLI testing.
Above you can have a closer look at the CPU, memory and PSU used in the setup. The 2600k used for testing was from batch L040B165.
Overclocking Methodology
At Hardware Canucks, we understand we have a diverse reader base and to represent a variety of user types, so we put the Z68XP-UD5 through three types of tests.
We did stability testing a little differently for the Sandy Bridge platform than usual. The main stability test used was Linpack (LinX version 0.6.4) with memory usage set to 2,560MB and 25 loops run. In the enthusiast world, Linpack is a benchmark designed to measure performance on Intel CPUs in GFlops. However, it's also a very useful tool for checking the stability of a CPU and memory. LinX picks up very quickly and if you are able to complete a 25 loop test with the specifications above your system is likely stable or very close to it. Typically we would run LinX much longer than 25 loops and add in Prime95 and OCCT; however there have been reports of degrading Sandy Bridge CPU overclockability with running these types of torture tests for long periods.
To avoid risking damage to the processor, after LinX stability was achieved, 2 runs of 3DMark Vantage and 2 runs of 3DMark 11 were run to test 3D stability. Once an overclock passed these tests, this is the point deemed as “stable” for the purposes of this review.
Windows 7 Service Pack 1 was installed to take advantage of the Advanced Vector Extensions (AVX) with Sandy Bridge processors. Intel AVX is a 256-bit SIMD floating point vector extension of Intel architecture. The BIOS used for overclocking and benchmarking was version F4, dated 09/01/2011.
Benchmarking Methodology
Benchmarks in the System Benchmarks section will be a comparison of the i7 2600k at stock speed, at auto overclock speed as set by QuickBoost, and at maximum 24/7 overclock to give an idea of how much performance a user can gain when overclocking the Z68XP-UD5.
For stock testing, optimized defaults were loaded putting the CPU at 3,501Mhz (35 x 100.3) and memory at 669Mhz and 9-9-9-24 1T timings. Optimized defaults enable Turbo by default hence the 3,501Mhz instead of 3400Mhz which is the stock speed of the processor. The auto overclocked speed on the i7 2600k for ET6 (QuickBoost) was 4,212Mhz (42 x 100.3) with memory at 669Mhz and 9-9-9-24 1T timings. The overclocked speed on the i7 2600k for 24/7 stability was 5,002Mhz (50 x 100.03) with memory at 1,067Mhz and 9-9-9-28 1T timings. Windows 7 Ultimate 64 bit was used with SP1 installed and SSD caching in enhanced mode was used.
- Beginner Overclocker - To represent a beginner overclocker or a mainstream user that wants to have a quick and easy way to get some extra performance we used the QuickBoost Level 3 setting found in the ET6 utility.
- Experienced Overclocker - To represent an experienced overclocker that is looking for the optimal 24/7 overclock to maximize system performance while keeping voltage and temperatures in check we overclocked the Z68XP-UD5 manually and stopped when we started to get concerned with voltage levels.
- Advanced Bencher - To represent the bencher that is looking for short benchmark runs at absolute maximum CPU and memory clocks we tested with sub-zero cooling and higher than recommended voltages. More on this is found in the sub-zero testing section.
