Silverstone Zeus 1200W Power Supply Review
by Michael "SKYMTL" Hoenig     |     February 17, 2008
Efficiency Testing
At lower wattages the ZM1200 struggled a bit but it kept its power consumption at more than acceptable levels; the power consumption of 12W when the system was turned off was also extremely good. However, as load increased it seems like this power supply got a second wind by posting some very good numbers. You will also notice that Silverstone’s new flagship power supply was able to complete our Extreme Load Test by pulling a whooping 1058W from the wall. Since the other power supplies have not been put through this test, there are no results for them here.
Voltage Regulation Testing
+3.3V Regulation
Here we go again with next to no variance on the +3.3V rail since modern computer systems do not use this rail much at all. The results are an almost foregone conclusion.
+5V Regulation
+5V regulation was a bit more interesting but the Zeus held things together quite nicely all the way into out most stressful test. While there was a bit more movement than we have seen with some of the past power supplies, a 0.05V change from idle to high load is a great result.
+12V Regulation
Once again like in past reviews we see a small difference in the voltages going from CPU LOAD to GPU Load and this is probably due to minor variations between the PCI-E and EPS12V connector. Nonetheless, this is the most important of the voltage regulation tests and it shows the Silverstone Zeus performing admirably well through even the most stressful situations. One thing that we were a bit surprised to see was seemingly sudden voltage drop between the Idle and CPU Load but it was not anywhere near enough to get concerned about. When looking at these results, it is more than obvious that this power supply is ready to play with the Big Boys.
Latest Reviews in Power Supplies
December 23, 2009
As prices for quality power supplies fall, products that were once out of reach are now accessible to consumers who are on a budget.  With the ever-increasing power demands of the most modern componen...
September 2, 2009
These days, power supplies seem to be a dime a dozen but when big-name manufacturers enter the market with their own units, people stand up and take notice.  That is why when we received XFX's brand n...
August 5, 2009
In the highly competitive power supply market, cheap products are a dime a dozen.  For the last few years, Corsair has shown us that well-priced power supplies can still perform above and beyond our e...
