Testing Methodology Testing MethodologyTesting a drive is not as simple as putting together a bunch of files, dragging them onto folder on the drive in Windows and using a stopwatch to time how long the transfer takes. Rather, there are factors such as read / write speed and data burst speed to take into account. There is also the SATA controller on your motherboard and how well it works with SSDs & HDDs to think about as well. For best results you really need a dedicated hardware RAID controller w/ dedicated RAM for drives to shine. Unfortunately, most people do not have the time, inclination or monetary funds to do this. For this reason our testbed will be a more standard motherboard with no mods or high end gear added to it. This is to help replicate what you the end user’s experience will be like. Even when the hardware issues are taken care of the software itself will have a negative or positive impact on the results. As with the hardware end of things, to obtain the absolute best results you do need to tweak your OS setup; however, just like with the hardware solution most people are not going to do this. For this reason our standard OS setup is used. However, except for the Vista load test times we have done our best to eliminate this issue by having the drive tested as a secondary drive. With the main drive being a Phoenix Pro 120GB Solid State Drive. For synthetic tests we used a combination of the ATTO Disk Benchmark, HDTach, HD Tune, Crystal Disk Benchmark, IOMeter, AS-SSD and PCMark Vanatage. For real world benchmarks we timed how long a single 10GB rar file took to copy to and then from the devices. We also used 10gb of small files (from 100kb to 200MB) with a total 12,000 files in 400 subfolders. All tests were run 4 times and average results are represented. In between each test suite runs (with the exception being IOMeter which was done after every run) the drives are cleaned with either HDDerase, SaniErase or OCZ SSDToolbox and then quick formated to make sure that they were in optimum condition for the next test suite. Processor: Core i5 2400 Motherboard: Asus P8P67 Deluxe Memory: 8GB Corsair Vengeance "Blue" DDR3 1600 Graphics card: Asus 5550 passive Hard Drive: 1x Seagate 3TB XT, OCZ 120GB RevoDrive Power Supply: XFX 850 Unless otherwise noted the drives used were: 5400rpm: Western Digital Blue 500GB Toshiba HDD2K11 1TB (12.5mm) Western Digital Scorpio Blue 1TB (WD10JPVT) 7200rpm: Hitachi 7K750 750GB Seagate Momentus (ST9750420AS) 750GB Western Digital Scorpio Black 750GB Seagate Momentus XT 500GB Western Digital Scorpio Black 250GB 10,000rpm: Western Digital Velociraptor (HLFS) 150GB | ||||
