| by AkG | March 5, 2008 | ||
| Installation Installation ![]() Installation of the Silentator is not a user friendly proposition and it can be fairly “tricky” to install. The installation is a lot easier if you have ever installed a Thermalright Ultima 90 as the mounting hardware is very similar in design yet not as well executed. ![]() As with the Ultima 90, the fan must not be installed on the heatsink when you install it or you will not be able to tighten down the two large spring loaded retaining screws that secure the heatsink to the motherboard. I admit that this issue nearly caught me but luckily I remembered my first Ultima 90 installation and was able to spare myself the ego stripping “2 steps back, 1 step forward” dance that this can cause. ![]() The first part of installation of the Silentator requires you to screw down the retaining brackets and small red washers via the motherboard's CPU heatsink mounting holes in order to attach the backplate. The first screw can be difficult to manage as you have to line up the motherboard and backplate perfectly; this issue is compounded by the fact that rubber washers need to be installed between the two top retaining brackets and the motherboard itself. However, once you have the first screw done it becomes a lot easier to get the rest. Overall it is quirky, but not overly difficult if you take your time and don’t allow yourself to become frustrated. When this is done one simply has to apply TIM to the CPU, place the Silentator in position and screw in the two large spring load screws. ![]() In comparison to the heatsink installation, the fan installation is extremely easy and straightforward. If you are planning on only using the one fan that is included you must make sure that the fan is positioned with the right “face” pointing inwards (on the fan frame are two arrows showing blade rotation and air direction) so that air is blown through the fins and not “sucked” out. The mounting of the fan is accomplished via the wire brackets that run the length of each side of the heatsink in their own little slot. At both ends of the wire bracket there is a short, complex “bend” so that the bend actually fits snuggly into a hole in each of the four corners of the fans case. Since the fan is under continuous tension this snug fit ensures that the fans air goes through the heatsink fins and not just around the edges of the fan’s case. ![]() One interesting thing about this mounting system is that you can in theory mount this cooler with the fan pointing in any direction you choose. You are literally only limited by the space available around the heatsink on your motherboard. For the majority of motherboards on the market you should have no trouble mounting this cooler in any direction you want. The only issue we had with installation has to do with the fact that the heatsink sits very close to the top edge of the motherboard. In all 3 of the 4 possible orientations installing at least one of the two wire retaining brackets would be extremely difficult to install inside a computer case due to lack of room to maneuver, and the 4th orientation (fan near GPU pointing up towards top of case) would be just as hard if two fans were used on the Silentator. It is for this reason we strongly recommend installing the fan before you reinstall the motherboard. It is also worth mentioning that while both wire brackets are the same and therefore there is no left or right bracket to mix up, it is very easy to install the brackets upside down. This of course does “look wrong” but it will still work some extent. This is certainly not a major issue and is really more of an annoyance than anything. ![]() The largest potential negative point about this mounting setup (and one that it shares with the Ultima 90) is that one of the two mounting brackets can touch and short out motherboard capacitors, especially if the capacitors are the older (and thus taller) style. On newer motherboards that use solid capacitors there is usually more than enough room and this should this should not be an issue. If your motherboard makes this an issue, simply repositioning the mounting brackets to the alternate orientation may alleviate the situation. ![]() If your motherboard has capacitors on two sides of the CPU socket, or if your chipset heatsinks don’t allow for the alternate mounting direction you may have problems. Basically if your board uses tall heatsinks and yet has the older style capacitors you may not be able to install the Silentator. Due to this potential issue proper research should be done in making sure that mounting the Silentator is possible on your motherboard. As a very nice bonus Coolink includes all the necessary hardware to install a second fan. This was especially nice as most companies charge extra for those little wire mounts and strips of rubber. We will show the benefits (if any) of using a 2nd fan in a push/pull setup bring later in this review. Either way this attention to the smaller points like this really shows that Coolink wants this CPU cooler to not only be quiet but be powerful as well. Also on the positive side, and unlike some tower style cooler the Silentator's height should not be a concern for most cases. However, if your case is like ours and it supports door mounted fans you will find it a tight fit to close the door with these fans installed. When installed in a CoolerMaster CM690 there was not enough room for both as the door fan would have been “too close for comfort”. Equally important is that while it is a wide tower it is tall enough that its width was not quite a concern on either a Gigabyte p35 DS4 or Asus Maximus boards. ![]() While the tower itself did not touch or rub any surrounding parts, the same can not be said for the fan brackets as they did show a tendency to poke things around them. The best example of this touching was with the North Bridge heatsink where the bottom of one the fan brackets actually rests on top it and had to be bent slightly to make it hold that corner of the fan in properly in place. Depending on your motherboard's chipset placement (and / or if you use an aftermarket chipset cooler) this may be a big issue for you; either way this touching does mar an otherwise simple yet elegantly effective fan mounting system. While the installation of the Silentator is easier than some other CPU cooling solutions we have seen in the past the Silentator’s heatsink installation is not very user friendly and you need to have a lot of experience in installing tower coolers for it to be considered quirky and not a pain in the butt. Total installation time, including removal of old heatsink TIM was about 12 minutes. If you are not used to this type of installation or do not plan out in advance how you are going to do it you can expect this time to be doubled at the very least. | ||
