Quantcast
Crucial M4 256GB SSD Review
Author: AkG
Date: August 25, 2011
Product Name: Crucial M4 256GB
Part Number: CT256M4SSD2
Warranty: 3 Years
Purchase at NCIX: | UK
Share |
Testing Methodology
Testing a drive is not as simple as putting together a bunch of files, dragging them onto folder on the drive in Windows and using a stopwatch to time how long the transfer takes. Rather, there are factors such as read / write speed and data burst speed to take into account. There is also the SATA controller on your motherboard and how well it works with SSDs & HDDs to think about as well. For best results you really need a dedicated hardware RAID controller w/ dedicated RAM for drives to shine. Unfortunately, most people do not have the time, inclination or monetary funds to do this. For this reason our testbed will be a more standard motherboard with no mods or high end gear added to it. This is to help replicate what you the end userís experience will be like.
Even when the hardware issues are taken care of the software itself will have a negative or positive impact on the results. As with the hardware end of things, to obtain the absolute best results you do need to tweak your OS setup; however, just like with the hardware solution most people are not going to do this. For this reason our standard OS setup is used. However, except for the Vista load test times we have done our best to eliminate this issue by having the drive tested as a secondary drive. With the main drive being a Phoneix Pro 120GB Solid State Drive.
For synthetic tests we used a combination of ATTO Disk Benchmark, HDTach, HD Tune, Crystal Disk Benchmark, IOMeter, AS-SSD and PCMark Vanatage.
For real world benchmarks we timed how long a single 10GB rar file took to copy to and then from the devices. We also used 10gb of small files (from 100kb to 200MB) with a total 12,000 files in 400 subfolders.
For all testing a Asus P8P67 Deluxe motherboard was used, running Windows 7 64bit Ultimate edition (or Vista for boot time test). All drives were tested using AHCI mode using Intel RST 10 drivers.
All tests were run 4 times and average results are represented.
In between each test suite runs (with the exception being IOMeter which was done after every run) the drives are cleaned with either HDDerase, SaniErase or OCZ SSDToolbox and then quick formatted to make sure that they were in optimum condition for the next test suite.
Processor: Core i5 2400
Motherboard: Asus P8P67 Deluxe
Memory: 8GB Mushkin DDR3 1300
Graphics card: Asus 5550 passive
Hard Drive: 1x Seagate 3TB XT, OCZ 120GB RevoDrive
Power Supply: XFX 850
SSD FIRMWARE (unless otherwise noted):
OCZ Vertex 2 100GB: 1.33
OCZ Vertex 3 MI 240GB: 2.11
Crucial C300 128GB: 006
Corsair Force 3 GT 120GB: 1.3
Patriot Pyro 120GB: 3.1.9
Corsair Performance 3 256GB: 1.1
Patriot Wildfire 120GB: 3.1.9
Kingston HyperX 240GB: 3.2.0
Crucial M4 256GB: 002
Latest Reviews in Storage
March 6, 2018
The Crucial MX500 follows in the footsteps of some of the best SSDs; the MX300 and MX200. But in a very competitive market, can it even compete these days?...
February 25, 2018
It is the FASTEST SSD we've ever tested, providing unbelievable benchmark performance but the Intel Optane SSD 900P also has some very serious limitations....
January 9, 2018
Toshiba has announced the new RC100 NVMe M.2 SSD Series, which targets value-oriented gamers, DIY system builders, and system integrators....
