Quantcast
AMD A8-3850 APU Review: Llano Hits the Desktop
Author: MAC
Date: June 29, 2011
Product Name: AMD A8-3850
Share |
Test Setups & Methodology
For this review, we have prepared four different test setups, representing all the popular platforms at the moment, as well as most of the best-selling processors. As much as possible, the four test setups feature identical components, memory timings, drivers, etc. Aside from manually selecting memory frequencies and timings, every option in the BIOS was at its default setting.
AMD Llano FM1 Test Setup
AMD Phenom II AM3 Test Setup
Intel Core i5/i7 LGA1155 Test Setup
Intel Core i3/i5/i7 LGA1156 Test Setup
Intel Core i7 LGA1366 Test Setup
*Although Windows Vista SP1 was our principal OS for the majority of benchmarks, we did use Windows 7 (with all the latest updates) when benchmarking AIDA64.*
For all of the benchmarks, appropriate lengths are taken to ensure an equal comparison through methodical setup, installation, and testing. The following outlines our testing methodology:
A) Windows is installed using a full format.
B) Chipset drivers and accessory hardware drivers (audio, network, GPU) are installed followed by a defragment and a reboot.
C)To ensure consistent results, a few tweaks were applied to Windows Vista and the NVIDIA control panel:
  • Sidebar – Disabled
  • UAC – Disabled
  • System Protection/Restore – Disabled
  • Problem & Error Reporting – Disabled
  • Remote Desktop/Assistance - Disabled
  • Windows Security Center Alerts – Disabled
  • Windows Defender – Disabled
  • Windows Search – Disabled
  • Indexing – Disabled
  • Screensaver – Disabled
  • Power Plan - High Performance
  • NVIDIA PhysX – Disabled
  • V-Sync – Off
D) Programs and games are then installed & updated followed by another defragment.
E) Windows updates are then completed installing all available updates followed by a defragment.
F) Benchmarks are each run three times after a clean reboot for every iteration of the benchmark unless otherwise stated, the results are then averaged. If they were any clearly anomalous results, the 3-loop run was repeated. If they remained, we mentioned it in the individual benchmark write-up.
Here is a full list of the applications that we utilized in our benchmarking suite:
  • AIDA64 Extreme Edition v1.50.1200 & v1.80.1459 Beta (Windows 7)
  • ScienceMark 2.0 32-bit
  • MaxxMEM2 Preview
  • wPrime Benchmark v2.03
  • HyperPI 0.99b
  • PCMark Vantage Advanced 64-bit Edition (1.0.2.0)
  • Cinebench R10 64-bit
  • Cinebench R11.5.2.9 64-bit
  • WinRAR 3.94 x64
  • Photoshop CS4 64-bit
  • Lame Front-End 1.0
  • x264 Benchmark HD (2nd pass)
  • 7-Zip 9.20 x64
  • POV-Ray v3.7 beta 40
  • Deep Fritz 12
  • 3DMark06 v1.2.0
  • 3DMark Vantage v1.0.2
  • Crysis v1.21
  • Far Cry 2 1.02
  • Left 4 Dead version 1.0.2.3
  • Valve Particle Simulation Benchmark
  • Word in Conflict v1.0.0.0
  • Resident Evil 5 1.0.0.129
  • X3: Terran Conflict 1.2.0.0
That is about all you need to know methodology wise, so let's get to the good stuff!
Latest Reviews in Featured Reviews
March 17, 2015
Another year and another TITAN is upon us.  This time NVIDIA is launching the TITAN X, a card that sports an 8 billion transistor GM200 core, 12GB of memory and unbelievable performance....
March 9, 2015
GIGABYTE's X99-SOC Champion seems to have everything it takes to become a legendary motherboard.  It has high end overclocking built into its bones and a low price but will that lead to success?...
February 24, 2015
The GTX 960 is a polarizing graphics card but we have five of the best models on the market going head to head.  These may just change your opinion of NVIDIA's latest GPU....
