Review Contents:
Thermaltake Sword M Super Tower Case w/Liquid Cooling Review
by Michael "SKYMTL" Hoenig     |     February 3, 2008
Some Assembly Required
Before I go on prattling about the exterior design, it has to be mentioned that in the same vein as all things Ikea that the Sword M requires a bit of assembly after you struggle to pull it from the vice-like grip of the box. Even though it is advertised as having “tool-less installation” you better take out your screwdriver to put your brand new case together.
As you can see, things look a tad bit…incomplete when the Sword M is taken out of the box for the first time. Both the top and bottom “lips” are missing from the front panel and the wheels still need to be installed. There are also two strips of masking tape that have been applied to keep the front drive covers on and this tape needs to be removed very carefully or you will leave some pretty nasty residue on the front panel.
There are four casters in total to install and each take four screws. I found that the best way to install these is to turn the whole case on its side, install one screw on the base plate and then line up the rest of the holes. It might seem a bit tedious but flipping the Sword M over on its head causes some serious problems due to the two “roll bars” (read: handles).
Each individual caster looks to be what you would find on a standard office chair which means they are relatively heavy duty. Every one of them has a brake so you can easily stop the Sword from moving from side to side.
Above and below the front panel of the Sword M you will need to install a pair of aluminum “lips”. The bottom one is quite easy to install with the included screws but installing the one for the top is a bit of a pain. Thermaltake provides you with a long metal straw-like dowel which has to be pushed through two sets of holes. Not only does this take the hand-eye coordination of a brain surgeon but also some pounding with a rubber mallet since the pieces are slightly unaligned.
February 15, 2010
Cooler Master has a long history of building quality cases and in this review we take a look at their limited edition HAF 932 AMD Edition enclosure.  This case offers all of the best features from the...
January 31, 2010
The mid tower case market is cluttered with products all vying for your attention but Silverstone's new Fortress FT02 dares to be different by incorporating a new "stack cool" design for component pla...
January 26, 2010
Lian Li is a case manufacturer that has been long known for their outstanding attention to detail and high end quality of everything from high-end lower-tier chassis.   In this review we take a look a...
LinkBacks (?)
LinkBack to this Thread: http://www.hardwarecanucks.com/forum/hardware-canucks-reviews/4408-thermaltake-sword-m-super-tower-case-w-liquid-cooling-review.html
Posted By Date
Do you ever just go on crazy spending frenzies? - Page 5 - The Grey Area - Tweaking Obsession February 14, 2010 07:57 AM
Do you ever just go on crazy spending frenzies? - Page 5 - The Grey Area - Tweaking Obsession February 12, 2010 06:19 PM
Thermaltake Sword M Super Tower Case w/Liquid Cooling Review - [OC]ModShop November 21, 2009 03:25 PM
Review of ThermalTake SwordM VD500LBNA, Review ThermalTake SwordM VD500LBNA - Cases November 2, 2009 12:11 AM
ninemsn Shopping October 6, 2009 01:05 PM
Rusty's Optima mATX mod DONE!!! - Overclockers Australia Forums September 27, 2009 10:25 PM
techPowerUp! :: Review Database September 6, 2009 11:55 AM
Thermaltakeusa Â» Chassis Â» Full Tower Â» SwordM LCS : SwordM LCS VD500LBNA August 9, 2009 11:15 AM
i7 Gaming Rig Build - Building - Desktops - Whirlpool Broadband Forums August 7, 2009 01:22 AM
Bienvenido a Thermaltake July 22, 2009 04:30 AM
Thermaltakeusa Â» Chassis Â» Full Tower Â» SwordM : SwordM VD5000BNA July 5, 2009 06:05 AM
Review of ThermalTake SwordM VD500LBNA, Review ThermalTake SwordM VD500LBNA - Cases June 20, 2009 03:18 AM
Thermaltakeusa Â» Chassis Â» Liquid Cooling Chassis Â» SwordM LCS : SwordM LCS VD500LBNA May 18, 2009 04:29 PM
Thermaltake Sword M Super Tower Case w/Liquid Cooling Review May 14, 2009 12:39 PM
Preporucite mi kuciste - PC Ekspert Forum May 12, 2009 11:30 PM
Thermaltakeusa Â» Chassis Â» Full Tower Â» SwordM Series Â» SwordM LCS : SwordM LCS VD500LBNA May 5, 2009 03:12 PM
What is the best watercooling kit out there? - SLI Zone Forums May 4, 2009 02:21 PM
Thermaltake Sword M Super Tower Case w/Liquid Cooling Review April 25, 2009 08:33 AM
Thermaltakeusa Â» Chassis Â» SwordM Series Â» SwordM LCS Â» SwordM LCS : SwordM LCS VD500LBNA April 24, 2009 12:03 PM
Thermaltakeusa Â» Liquid Cooling Â» Liquid Cooling Chassis Â» SwordM LCS : SwordM LCS VD500LBNA April 20, 2009 05:04 AM
Daily Reviews Summary 02/06/08 April 17, 2009 08:31 PM
FS for charity. Enermax Pro82+ 625W & Price Drops on ASUS 8800GT / SwordM Case - RedFlagDeals.com Forums April 9, 2009 03:57 PM
Bienvenido a Thermaltake April 7, 2009 06:23 AM
Thermaltakeusa Â» Chassis Â» SwordM Series Â» SwordM Â» SwordM : SwordM VD5000BNA April 6, 2009 03:04 AM
Thermaltakeusa Â» Chassis Â» Full Tower Â» SwordM Series Â» SwordM : SwordM VD5000BNA April 4, 2009 02:02 PM
