Quantcast
Get Adobe Flash player
MSI GeForce GTX 580 Lightning Review
Author: SKYMTL
Date: May 1, 2011
Product Name: MSI GTX 580 Lightning
Part Number: N580GTX-Lightning
Warranty: 3 Years
Share |
Flipping the Lightning…DIP Switches Aplenty
Turning the Lightning over reveals a PCB that is far from the reference design in every way possible. Instead of lengthening the PCB to incorporate their high end components, MSI has added extra width by incorporating a small ˝” lip on the card’s leading edge.
MSI has gone the same route as Gigbayte does with their Super Overclock series by equipping the Lightning with a quartet of NEC / Tokin Proadlizer. Laid out in a 3+1 GPU to memory configuration, these chips provide high capacitance and low ESR to ensure the cleanest power possible gets to each section of the graphics card while providing 1000 uF of capacitance.
Along the PCB’s edge are three DIP switches with a fourth being located near the PCI-E slot connector. The main grouping of three includes an OPC Unlocker that allows the core to ignore any power limiter that has been placed upon it, a V-Switch for quick voltage tuning and a PWM Clock Tuner which essentially overclocks the PWM clock to 310Mhz from the reference 260Mhz. The fourth switch is dubbed XtremeCool for working around the GTX 580’s “cold bug” and should be used when overclocking with LN2.
Next to the three main DIP switches is a toggle used for quick BIOS switching. The Lightning holds two BIOSes onboard; one of which houses the standard overclocked file and another which is tailor-made for high end cooling solutions since it implements aggressive voltage presets. When used in conjunction with the XtremeCool toggle, this should allow extreme overclockers to completely bypass the dreaded GF110 cold bug.
Naturally, these are only the most visible features which hint at the Lightning’s overclocking prowess. Below the heatsink, there is a long list of upgraded components that will allow overclockers to really push this card to its absolute limits.
Latest Reviews in Video Cards
May 23, 2013
With the GTX 600-series slightly more than a year old, NVIDIA is now ready to start refreshing their GeForce lineup once again.  The first card out of the gate is their GTX 780, a $649 GK110-based fla...
April 23, 2013
AMD's HD 7990 has been rumored for more than a year but now it's finally here.  With it, we get a pair of Tahiti XT cores, 6GB of memory and an insanely quiet heatsink all wrapped into a $999 card tha...
April 8, 2013
NVIDIA's $170 GTX 650 Ti Boost has quickly become the go-to choice for gamers on a budget and board partners have been quick to jump on board.  In this roundup, we take a look at cards from ASUS, EVGA...
