Eldonko
Hardware Installation
To show you how hardware is going to fit on the P8Z68-V Pro we installed a Zalman CNPS10x Flex, a 4GB kit of G.Skill memory, and two GTX 460 video cards. The Zalman is an average-sized aftermarket CPU cooler so it should provide a good reference and the G.Skill kit is taller than most so we can see if there any clearance issues.
As you can see, there are no clearance issues whatsoever when it comes to this particular CPU cooler and the motherboard’s heatsinks. The only issue a user may run into is if all four memory slots are occupied and their CPU cooler has two fans installed. This would however be quite rare and could be worked around by simply removing the fan on the side of the memory slots.
Adding two video cards really shows how much space there is between the PRO’s slots. The video cards don’t block anything you need to get at and since the SATA ports are mounted at right angles. We also really like how ASUS uses GPU release buttons that are pushed down and are accessible from both sides. This avoids having to remove the first video card to get at the second one.
