| by 3oh6 | January 25, 2008 | ||
| Stability Testing & Overclocking Stability Testing & Overclocking: Before we actually get to some stability testing and overclocking, let's discuss exactly what our stability testing consists of and a few thoughts on stability testing for memory in general. Stability Testing Methodology:Memory stability, what constitutes stable? What is not considered stable? These questions get hotly debated in enthusiast forums all over the internet like little brush fires on the fringe of an inferno that play havoc with forest fire crews. Everyone has their own opinion about stability, especially when it comes to memory stability. For some, stable means they can do whatever it is on their computer without it crashing, blue-screening, or restarting; whether that means gaming or simply surfing the internet. To this user, stable means simply using the computer as they normally would. ![]() Of course, that is not what we would call stable and we do a lot more thorough testing before labeling a memory frequency/timing stable. One of the toughest types of programs on a system has been found to be distributed computing projects such as Rosetta@Home, Folding@Home, World Community Grid, and more. Running 24/7 crunching for one of these great causes is a sure way to find holes in a system if there is truly some instability, unfortunately it takes a considerable amount of time to use them for stability testing so we use the list of programs below to all but guarantee the system to be 24/7 distributed computing stable:
The above testing is quite exhaustive and has been found to provide us with a system that is stable and willing to run a distributed computing program 24/7 or hours of gaming without interruption or failure. This method of stability testing will not only be used for testing the stability of the overclocks but also the rated specifications outlined by the manufacturer. We have added the Specification Stability Testing section in response to finding a few kits of DDR3 memory not being able to stably run the specified frequency/timings at the rated voltage. As we can see from the screenshot, things didn't quite go as planned. As mentioned, many hours were spent testing a great number of combinations of secondary timings available to us through the BIOS or through Memset 3.4 within Windows and at no point were we able to run dual 32M SPi or Prime v25.4. One instance of SPi would continually fail and one thread of Prime would also fail within a few minutes of running. HCI Win Memtest passed two hours with ease and the 3D Mark benchmarks had no problem looping for 30 minutes each. Increasing the voltage to 2.00v in the BIOS allowed the system to run through our stability testing without issue as we will see below but this means the memory was actually receiving 2.06v. Stability Overclocking: It is now time to see what these modules do at more than just their specified timing sets. The decision to stay close to the specified voltage is an easy one. These DDR3 modules are still very new and it is hard to say exactly how much voltage is going to damage the Micron ICs and there have been no manufacturers offer a module at higher than 2.0v that we have seen. This would indicate that going over 2.0v isn't going to be highly recommend so we have gone up to 2.06v (A = actual) and tested for maximum overclocking ability at three timing sets, 6-6-5-18, 7-7-7-21, and 8-7-6-18. Here is the graph of how far we got: ![]() After finding out that we needed a pinch more voltage to get these modules running at the specified frequency with the tight 7-7-7 timings we weren't sure what was going to happen during the overclocking. Combine that with the fact that the rated voltage is basically all we were willing to put through these modules for 24/7 stability testing, we don't see a whole pile of overclocking headroom. Of course, when the modules are already rated for ridiculously high frequency with tight timings, you can't really expect much. ![]() You may also notice that the voltage is listed as "actual" or designated like this (A). As described in the Specification Stability Testing section, this particular Asus P5K3-Dlx over-volts memory from what is selected in the BIOS. For every overclock, we have tested the voltage to be 0.06v above what was set in the BIOS. In the screenshots below, Asus AI Suite presents the voltage that is set in the BIOS and the text file we have added, lists the actual measured voltage by the digital multi-meter. Click for full size screenshot... | ||
| Latest Reviews in RAM | |||||||||
