Categories
Review Contents:
ATI Radeon HD3870 X2 1GB Review
by Michael "SKYMTL" Hoenig     |     January 28, 2008
The Trials of Overclocking
Some cards embrace overclocking with open arms but there are a few things about overclocking the HD3870 X2 that you should be made aware of. First of all there is the little caveat of the power connectors.
Like with the HD2900XT, there is one 6-pin and one 8-pin PCI-E connector on this card. We tried a few combinations to see if it was possible to overclock with a pair of 6-pin connectors plugged in and these are the results we got.
On the left we see the ATI Overdrive option that comes up when both the 8-pin AND the 6-pin PCI-E connectors are installed. Meanwhile, when only two 6-pin connectors are plugged there is no Overdrive option though the card operates perfectly normal at stock speeds in any game. There are ways around the need for an 8-pin connector for overclocking and if you need any pointers for this, please feel free to post on the HD3870 X2 comment thread in our forums.
Even with the 8-pin connector installed, overclocking didn’t go very far with this engineering sample.
Max Overclocks:
Core: 865Mhz
Memory: 1892Mhz (DDR)
These clocks represent a pretty pathetic overclock of 50Mhz on the cores and 92Mhz on the memory. Considering the GDDR3 memory is rated at 2Ghz (DDR) I would think that either ATI tightened the timings or there is insufficient voltage running to it to facilitate higher overclocks. The core is another matter altogether; all signs point to the dreaded issue that plagued the early HD3870 512MB cards which couldn’t clock past the 862 to 867Mhz mark. These cards needed a BIOS flash in order to overclock past that point but flashing the BIOS on this card with two GPUs is a bit beyond the scope of this review. It is possible that this is an issue with our engineering sample and won’t carry into the actual production cards.
As you can see, these minor overclocks net us less than 200 points in 3DMark06 and would provide next to no performance increase in games. Also, as we discussed before you have to overclock both GPUs and memory separately like you would in a dual card Crossfire setup. The process goes something like this:
1. Overclock GPU #1
2. Overclock memory associated with GPU#1
3. Test Clocks
4. If overclock passes, accept Overclock
5. Overclock GPU #2
6. Overclock memory associated with GPU#2
7. Test Clocks
8. If overclock passes, accept Overclock
ATI should make things easier by just allowing one GPU to determine the clocks of the other. It would simplify all our lives.
Latest Reviews in Video Cards
September 2, 2010
It is rare for more than two graphics chips to be launched at the same time.  However, NVIDIA is bucking this trend by introducing SEVEN new GPUs into the market with immediate availability.  They ran...
August 29, 2010
Multi monitor gaming setups are expensive but through the need for an active DisplayPort connector on at least one monitor, ATI's Eyefinity was additionally limiting for potential customers.  Prior to...
August 23, 2010
Mafia II is the latest blockbuster from 2K Games which has incorporated a number of features which bring a more interactive experience to gamers.  In this article, we see if these "Graphics Plus" tech...
LinkBacks (?)
LinkBack to this Thread: http://www.hardwarecanucks.com/forum/hardware-canucks-reviews/4236-ati-radeon-hd3870-x2-1gb-review.html
Posted By Date
ATI Radeon HD 3870 X2 1GB June 23, 2010 07:34 AM
AMD Processors Forums - 3870X2 benchmark May 3, 2010 12:20 PM
3870 X2 Reviews - XtremeSystems Forums April 17, 2010 09:49 PM
GTX4** Series up for preorder - GotGames.com.au March 27, 2010 01:21 AM
3870x2 reviews are here and where to buy - AnandTech Forums March 21, 2010 02:41 PM
ATI Radeon HD3870 X2 1GB Review March 10, 2010 01:55 PM
techPowerUp! :: Review Database March 5, 2010 01:21 AM
[Review] AMD ATi Radeon HD 3870X2 - Foros de CHW February 24, 2010 06:07 PM
Need 3870X2 measurements! February 13, 2010 01:40 AM
The Official 3870X2 Reviews Thread - Overclockers Forums February 9, 2010 10:13 AM
HD3870X2 reviews thread - Graphic card and Display January 27, 2010 07:23 AM
3870X2 Review Links - Overclock.net - Overclocking.net December 27, 2009 03:03 PM
[??] AMD ATi Radeon HD 3870X2(vs GeForce 8800 Ultra) December 17, 2009 09:24 AM
[Review] AMD ATi Radeon HD 3870X2 - Página 4 - Foros de CHW December 16, 2009 03:42 PM
COD4 PC shuts down help pls - HEXUS.community discussion forums December 2, 2009 06:04 PM
8Pin PCI-E connector - jonnyGURU Forums September 12, 2009 03:44 AM
[Topic Unique] ATI HD3850 | HD3870 | HD 3870 X2 September 7, 2009 01:10 PM
ATI Radeon HD 3870 X2 Discussion Thread - Monitors/Video July 31, 2009 06:18 AM
The 3870x2 Reviews Thread! - Rage3D Discussion Area July 27, 2009 04:27 PM
ÃÇÁÊØ´ÂÍ´ÃÕÇÔÇ ATI Radeon HD 3870 X2 - MonaVista's Webboard July 21, 2009 01:46 AM
8800GTS(G92)512MB ¡Ñº 3870x2 1GB «×é͵ÑÇä˹´Õ¤Ñº - OVERCLOCKZONE Forums July 10, 2009 06:54 AM
What is faster? 3870x2 or 2x3870 ? - Rage3D Discussion Area July 9, 2009 08:28 AM
3870 X2 Reviews - techPowerUp! Forums July 9, 2009 06:43 AM
AnandTech - 3870x2 reviews are here and where to buy June 28, 2009 06:07 AM
GameSpot Forums - PC Hardware Discussion - 3870 X2 or 8800 GTX June 16, 2009 07:31 AM
HD3870 X2 versus HD3870 512MB Crossfire June 12, 2009 07:24 PM
Which beta driver to use for 3870 Crossfire in Crysis? - [H]ard|Forum June 11, 2009 08:01 AM
[Review] AMD ATi Radeon HD 3870X2 - Página 2 - Foros de CHW June 10, 2009 06:52 AM
ATI Radeon HD3870 X2 1GB Graphics Card Review June 8, 2009 08:42 PM
3870x2 reviews thread... - nV News Forums June 1, 2009 10:08 AM
AnandTech - Rumor Section: About the new GPU's June 1, 2009 07:27 AM
The Official 3870X2 Reviews Thread - Overclockers Forums May 24, 2009 09:21 PM
3870 X2 Reviews - techPowerUp! Forums May 24, 2009 04:18 PM
8800gts 512 vs 3870x2 - Futuremark / YouGamers Forums May 24, 2009 07:25 AM
Which is stronger? 2 hd3870 in crossfire mode or 1 hd3870x2? - Yahoo! Answers May 17, 2009 09:40 AM
High end AMD gaming rig: why and why not? May 10, 2009 09:56 AM
Tecnoscopio: Review de la Radeon HD3870 X2 May 9, 2009 04:50 PM
3870x2 has 860mhz lock again - Page 3 - XtremeSystems Forums May 6, 2009 01:46 AM
3870's in CF vs 3870x2 - XtremeSystems Forums April 25, 2009 03:09 PM
2 MCW 60 on a 3870X2? - Page 2 - XtremeSystems Forums April 17, 2009 01:59 AM
ATI Radeon HD3870 X2 1GB Graphics Card Review April 12, 2009 08:15 AM
HD3870 X2 versus HD3870 512MB Crossfire April 12, 2009 05:09 AM
DailyTech - 1/28/2008 Daily Hardware Reviews -- Radeon HD 3870 X2 Edition April 10, 2009 10:03 PM
New ATI drivers improve HD3870X2 performance significantly!! - HEXUS.community discussion forums April 10, 2009 10:09 AM
PC upgrades needed [Sims 3]? - Yahoo! Answers April 10, 2009 05:27 AM
Forum DivXPLANET > Dünyan?n en h?zl? ekran kart? April 9, 2009 01:31 PM
Need 3870X2 measurements! - Overclock3D Forums April 5, 2009 05:49 PM
Custom Cooling 3870 X2's - Overclock.net - Overclocking.net April 5, 2009 12:36 PM
Untitled document April 5, 2009 03:01 AM
