Categories
Review Contents:
Mediasonic Dual Bay RAID Hard Drive Enclosures Review
by AkG     |     January 13, 2008
Sandra Removable Storage Benchmark
This test was run with the removable storage benchmark in Sandra XII Standard. All of the scores are calculated in operations per second and have been averaged out from the scores of 4 test runs.
Please note that both enclosures' USB results were the same with the biggest deviation being 2ops/min. For ease of use only 1 set of USB results have been included.
As you can see, FireWire 400 and USB have nearly identical numbers when it comes to RAID 0 and it is only in RAID 1 and single mode that the 1394a standard starts to distinguish itself. Once again, proving that a higher theoretical limit does not equate to higher real world numbers. Regardless of how well both the USB and FireWire 400 results are, FireWire 800 is simply in a league of its own.
Extended Runtime Testing
Since both these units are marketed towards the SOHO environment, it is reasonable to expect them to be able to handle extended usage with random multiple requests for data. To test how robust these units are and how well their cooling would work under a heavy workload, both enclosures were subjected to 48 hour nonstop sessions. During this time the enclosures were directed to not only fill and then empty their contents but were also expected to handle multiple simultaneous read and write requests from different computers on the network.
After 48hrs of nonstop use both enclosures hard drives were warm to the touch but neither was hot and both appeared to be adequately cooled. More importantly the Texas Instrument chip and both Oxfords did get very warm, some would say “hot” but neither was in risk of being damaged and they continued to work perfectly. Both enclosures passed this torture test and continue to work fine.
The only issue we had was with the Firewire-equipped and more expensive SU2FWB. Even before testing started it suddenly stopped being recognized by any system, regardless of whether the lone 1394a or either of the 1394b ports were used. Strangely it was instantly recognized when the USB connection was used. After replacing the FireWire 800 pci card and using a different system for 1394a it still did not work.
It was then discovered that the FireWire cables and the FireWire ports themselves on the SU2FWB had become loose and allowed the cables enough flex in the ports which causes random disconnects. This problem was only temporarily alleviated by replacing the cable with a known good one. The final solution was to place the unit on its side and use the known good cable. This new orientation, did not allow the cables to sag enough to disconnect and the different orientation also did not in any way affect performance nor did it seem to affect hard drive temperatures. If one is planning on using this model in a SOHO environment you may want to invest in a good cable management system that supports the cable and seriously consider the cables that come with the unit as “backup only” cables.
Latest Reviews in Storage
February 25, 2010
Many people have shied away from SSDs due to their somewhat limited storage capacity and high price for the drives.  Spindle-based hard drives on the other hand have massive amounts of storage space b...
February 11, 2010
In a computing world that is seeing its storage needs rapidly expand, we have seen a quick surge in the capacities of today’s hard drives. While we all know that the recent SSD revolution has produced...
January 20, 2010
As the SSD marketplace expands at a near-breakneck pace, OEMs and manufacturers alike are moving quickly to cover as many price points as possible.  One of the most popular portions of this market doe...
LinkBacks (?)
LinkBack to this Thread: http://www.hardwarecanucks.com/forum/hardware-canucks-reviews/4069-mediasonic-dual-bay-raid-hard-drive-enclosures-review.html
Posted By Date
Mediasonic Firewire & USB Dual Bay RAID Hard Drive Enclosures @ Hardware Canucks March 7, 2010 10:45 AM
Mediasonic Dual Bay RAID Hard Drive Enclosures Review - [OC]ModShop February 16, 2010 03:10 AM
Mediasonic RAID enclosure January 14, 2010 04:37 PM
xvi.com: Topic: Dual Drive RAID Enclosure December 5, 2009 11:56 PM
Mediasonic Dual Bay RAID Hard Drive Enclosures Review - Madshrimps Forum Madness October 25, 2009 11:37 AM
» Mediasonic Firewire & USB Dual Bay RAID Hard Drive Enclosures @ Hardware Canucks October 4, 2009 09:00 AM
Daily Reviews Summary 01/15/08 June 21, 2009 03:20 PM
Mediasonic's new Dual Bay RAID Hard Drive Enclosures June 18, 2009 05:01 PM
Apple - Support - Discussions - HDD recommendation for Time Machine for ... June 10, 2009 09:57 PM
Apple - Support - Discussions - Firewire 800 enclosure in Canada ... May 28, 2009 12:27 PM
Québec I.T. :: Forum d'entraide informatique • View topic - Mon nouveau boitier externe RAID May 5, 2009 10:46 PM
Backup | ZeroZen April 22, 2009 12:12 AM
First Impressions: Early 2009 Mac mini - Page 9 - ehMac.ca April 12, 2009 11:41 AM
Backing up data via Burn/hard drive? - Canon HV20, HV30 & HV40 User Forum April 10, 2009 07:42 PM
Mediasonic's new Dual Bay RAID Hard Drive - PCSTATS.com April 7, 2009 02:28 PM
MADSHRIMPS - Hardware Reviews ,Crazy Projects, Modding Tutorials and Overclocking April 5, 2009 10:01 AM
Mediasonic Dual Bay RAID Hard Drive Enclosures Review April 4, 2009 07:33 PM
surly73's Bookmarks on Delicious April 3, 2009 03:01 PM
Mediasonic Web Store April 3, 2009 05:41 AM
Mediasonic Dual Bay RAID Hard Drive Enclosures Review April 3, 2009 01:27 AM
