Quantcast
Get Adobe Flash player
ASUS P8P67 PRO LGA1155 Sandy Bridge Motherboard Review
Author: MAC
Date: March 15, 2011
Product Name: ASUS P8P67 Pro
Part Number: P8P67 PRO B3
Warranty: 3 Years
Price Compare: US | UK
Share |
Package & Accessories
Now that we have gone over the P8P67 PRO’s chipset and its extensive specifications, it is time to take a look at the packaging and the included accessories. At $190.00CDN+, this motherboard is firmly in the mainstream segment, so we expect to see at least a few included goodies.
Let's check it out:
Click on image to enlarge
For the P8P67 series, ASUS unveiled a new package design, and now they have added eye-catching B3 revision visuals as well. The box itself has a new black theme with an emphasis on the equally new DIGI+ VRM digital power design. The packaging is also adorned with logos illustrating this model's numerous features and specifications, and you will find quite a bit of additional information about all of the interesting ASUS-specific features on the back.
The accessories bundle is a little light on surprises, but honestly there's nothing missing. There are two SATA 3Gb/s cables and two SATA 6Gb/s cables, all of which feature 90-degree connectors. There is an expansion bracket with two USB 3.0 SuperSpeed ports, but this model doesn't come with the unique Front Panel USB 3.0 Box that ASUS have included with the higher-end P8P67 Deluxe. Lastly, there is the anti-EMI I/O panel, 2-Way SLI bridge connector, and Q-Connectors, which make attaching the case cables to the system panel connector a much easier process.
Here is a break down of the included items:
  • 2 SATA 3Gb/s Cables
  • 2 SATA 6Gb/s Cables
  • 2-port USB 3.0 Expansion Bracket
  • 3-port eSATA/USB PCI Expansion Bracket
  • 2-Way SLI Bridge Connector
  • I/O Panel
  • Manual / User Guide
  • Installation CD
  • Q-Connector
Now that we have taken a closer look at the accessories, let's do the same for the motherboard.
Latest Reviews in Featured Reviews
September 16, 2012
Corsair's Vengeance 2000 seems to combine everything a gamer could possibly want in a headset:  virtual 7.1 surround sound capabilities, long distance wireless operation and lightweight construction. ...
September 13, 2012
NVIDIA's new GTX 660 is aimed directly at the highly popular $199 to $249 price bracket.  Equipped with a Kepler-based GK106 core, this new card is meant to go head to head against AMD's HD 7870 while...
September 5, 2012
MSI's GTX 670 Power Edition OC has an enviable rap sheet:  it's performance nearly matches a GTX 680, there's a long feature list and the included Twin Frozr IV heatsink is cool and extremely quiet.  ...
