Seagate Momentus XT 500GB Hybrid Hard Drive Review
Status
Not open for further replies.
Vista Start Up / Adobe CS5 Load Time
Vista Start Up
When it comes to hard drive performance there is one area that even the most oblivious user notices: how long it takes to load the Operating System. While all the other tests were run with a Windows 7 operating system, this particular test uses another older test bed's “day to day” OS (copied over to our new testbed) which has accumulated a lot of crud over the months from installs and removals. We chose the Anti-Virus splash screen as our finish line as it is the last program to be loaded on start up.
As you can see, the Seagate Momentus XT really is a beast of a drive when it comes to real world performance. That 4GB of NAND started kicking in on about the third reboot and by the time we had gotten to about six reboots, the time had stabilized at fifty seven seconds. While it still trails even entry level (and older generation) Solid State Drives it does come awfully darn close AND you get a boat load more storage capacity.
Adobe CS5 Load Time
Photoshop is a notoriously slow loading program under the best of circumstances, and while the latest version is actually pretty decent, when you add in a bunch of extra brushes and the such you get a really great torture test which can bring even the best of the best to their knees. Let’s see how our review unit faired in the Adobe crucible.
Once again the Seagate Momentus is able to come within spitting distance of similarly priced SSDs. Sure it can't tie even the smallest SandForce Solid State drive, but the fact that ANY spindle based drive can come this close is impressive.
Conclusion
Conclusion
Unlike certain emerging technology segments, true innovation is hard to come by in mature markets like the one Momentus XT series plays in. Hard drive technology really hasn’t changed all that much for some time but Seagate has designed a product that shatters some longstanding beliefs and ends up setting new standards for performance. The impressive performance in some areas does come with a few pitfalls but for all intents and purposes, the Momentus XT proves itself to be one hell an upgrade for laptop users.
The performance numbers we saw in testing were interesting to say the least since synthetic tests really don’t do this drive any justice. Where it really takes a step away from the pack is in the all-important real world tests. In every application we tested, Seagate’s hybrid drive simply demolished the competition.
With that being said, there are a few caveats worth pointing out here. Under certain circumstances Seagate’s technology can boost the read speeds into the stratosphere but it simply can’t do it for every single file on the drive. To be blunt, 4GB of NAND – even high quality SLC NAND – is simply not enough. Today’s systems have huge storage requirements it would have been great to see at least 16GB for caching often-used files. In addition, the Adaptive Memory Technology doesn’t boost write speeds since the onboard NAND is purposely removed from the equation. It also needs time to learn usage habits so the differences between the XT and a standard hard drive may not be readily apparent from the get-go.
Hard drive technology hasn’t seen much forward progress in the past decade or so but Seagate’s Momentus XT represents an enticing glance into the near future. It leverages technologies from the SSD and HDD worlds in order to build a drive that’s able to successfully bridge the gap between the two. This is the first highly successful step for hybrid drives and once the design is refined, we may be looking at a series of products that can finally offer the perfect balance between price, performance and capacity.
Pros:
- Stunning real-world performance
- Reads vary from good to exceptional
- Decent write speeds for a 7200 RPM “laptop” drive
- 5 Year Warranty
- Reasonable price
Cons
- While still reasonably priced, it still is a lot of money for a 500GB, 7200rpm 2.5” hard drive
- 4GB of SLC NAND is simply not enough
- Write speeds are never boosted by the NAND
<img src="http://images.hardwarecanucks.com/image/akg/Storage/Momentus_XT/di.png" border="0" alt="" />
http://www.hardwarecanucks.com/foru...-hybrid-hard-drive-review-comment-thread.html
Status
