Categories
Review Contents:
Thermaltake TMG A1 AM2 CPU Cooler Review
by AkG     |     January 5, 2008
Testing Methodology
939 Test System Setup
Processor: AMD X2 4400+
Motherboard: A8N32-SLI deluxe
Memory: 2GB Corsair XMS pc3200
Graphics Card: Evga Geforce 6200
Hard Drives:
2x Seagate Barracuda 7200.10 320GB
2x Western Digital SE 120gb
1x Western Digital Se 200 Gb
Power Supply: 600W Seasonic S12
Case: Antec SLK3000B case with 1 120mm fan port for intake and 1 120mm fan port for air out.
AM2 Test System Setup
Processor: AMD X2 4800+
Motherboard: ASUS M2N32-SLI Deluxe
Memory: 2GB Corsair TwinX PC2-6400
Graphics card: Evga 7900gtx 512mb
Hard Drives:
1x Western Digital Raptor 150GB
2x Seagate 7200.10 320GB
1x Western Digtal Se16 500GB
Power Supply: Enermax Liberty 620W
Case: CM Stacker 830 w/ 8 Scythe E fans
All comparison testing was done on a closed case system with an ambient temperature of 15*C. Recorded temperatures were logged in CoreTemp. Load temperatures were taken after 1 hour of running Orthos’ blend test set at “10”. Idle temperatures were taken 15 minutes after Load testing ceased. Motherboard temperatures were recorded using SpeedFan.
Except where noted, Arctic Silver 5 thermal paste was used for all tests. Application of thermal paste was according to manufacturer's instructions, and allowed to cure for 48 hours under moderate load prior to testing. All tests were run 4 times and only best results are represented.
Notes about Overclocking
I consider 1.5volts to be the most that I would seriously consider for a moderate-to-long term overclock. Yes, you can go much higher but the longevity of the cpu is then called into question. Just as importantly AMD cpu’s should max out at LESS than 55c as this is also what I consider the safest, maximum long term overclocking temperature. For the purposes of these tests I was willing to overlook temperatures as long as they stayed below 60c.
With these two general guidelines I overclocked both systems until either one (or both) of these "rules" was broken.
Overclocking was accomplished by increasing HTT speed (AMD’s version of a front side bus) and then Vcore (only if necessary).
Before testing for idle and max temperatures Orthos blend test was run for 1 hour to make sure that the overclock was benchmarkable at a given clock speed and voltage. If Orthos finished with no errors, SuperPi set to 32m was run twice. After the stability testing was accomplished the given system was allowed to sit idle for 30minutes before starting the official tests. IF both of the above stated guidelines were not broken then testing continued with an increased overclock. These steps were then repeated until one or both of the general guidelines were broken.
Since they have no bearing on these tests, the RAM’s voltage and timings are not recorded, but needless to say they were loosened and the voltage was increased if necessary. Please do not consider this a full “how to” review on overclocking or “safe guidelines” for overclocking nor even an indicator on how well a given cpu will overclock. IF you are interested in OC’ing your system, and use these guidelines we at HWC take no responsibility for the results. Bad Things can happen if you are not careful.
Please note: The AM2 cpu used was one of the very first AM2 X2 4800+ processors released and are thus not indicative of how well the newer more refined versions will overclock. Regardless, overclocking of a cpu is completely luck of the draw and these are just the results that 2 cpus gave.
Notes about the “Stock” Cooler
BOTH system’s “stock” cooler was AMD’s higher-end 4 heatpipe heatsink. If you want a comparison to the more normal copper/aluminum cooler that usually ships with AM2 cpu’s please add 3 – 5 degrees to the stock temps.
Here are two pictures of the stock cooler used.
Latest Reviews in Cooling
March 15, 2010
When it comes to CPU coolers, most consumers usually have to choose between a low price or good performance since there are very few products on the market that feature both.  With their Traquillo, Ge...
January 28, 2010
When we last looked at Zalman's new CNPS10X family with the Extreme version, there seemed to be a lot to like but there were some shortcomings as well.  Zalman has now launched the Flex Edition which ...
January 5, 2010
At the upcoming CES 2010 show, Zalman will be showing a number of their new products which include cases, coolers and even some new 3D products. In this article, we take a quick, pictorial look at som...
LinkBacks (?)
LinkBack to this Thread: http://www.hardwarecanucks.com/forum/hardware-canucks-reviews/3942-thermaltake-tmg-a1-am2-cpu-cooler-review.html
Posted By Date
Daily Reviews Summary 01/06/08 January 31, 2010 12:52 AM
Computer fan November 21, 2009 03:30 PM
Review of ThermalTake TMG A1, Review ThermalTake TMG A1 - Cooling October 14, 2009 06:29 PM
Bienvenido a Thermaltake September 12, 2009 03:14 PM
ninemsn Shopping July 16, 2009 12:55 PM
Bienvenido a Thermaltake July 12, 2009 08:11 PM
techPowerUp! :: Review Database July 2, 2009 06:58 AM
» Thermaltake TMG A1 AM2 CPU Cooler Review @ Hardware Canucks June 24, 2009 12:30 PM
Bienvenido a Thermaltake June 4, 2009 08:16 AM
Thermaltakeusa Â» Cooler Â» CPU Cooler Â» AMD Socket 754 / 939 / 940 Â» TMG A1 : TMG A1 CL-P0371 April 27, 2009 08:41 AM
banjaluka.com forumi • Pogledaj temu - cooleri za procesor April 26, 2009 07:20 AM
Welcome to Thermaltake April 22, 2009 06:27 AM
Bienvenido a Thermaltake April 16, 2009 02:22 PM
Computer fan - Wikipedia, the free encyclopedia April 6, 2009 06:55 PM
Thermaltake TMG A1 CPU Cooler Review April 4, 2009 09:24 PM
Thermaltake TMG A1 CPU Cooler Review April 3, 2009 06:36 AM
Thermaltakeusa Â» Cooler Â» CPU Cooler Â» AMD Socket AM2 / AM2+ Â» TMG A1 : TMG A1 CL-P0371 April 2, 2009 04:04 PM
