Get Adobe Flash player
NVIDIA GeForce GTX 460 SE 1GB Review
Author: Michael "SKYMTL" Hoenig
Date: November 21, 2010
Product Name: NVIDIA GeForce GTX 460 SE 1GB
Price Compare: US
Share |
A Closer Look at the Gigabyte GTX 460 SE OC
Gigabyte’s Overclocked version maintains the standard 3400Mhz QDR memory speed but the core has been pushed to a level that will likely have a profound impact upon performance.
As with most of their GTX 460 cards, Gigabyte has used their custom heatsink for this particular product but otherwise it remains very close to the reference GTX 460 1GB / 768MB versions. There are some upgraded components on the custom PCB though.
Backplate connectors also stay bog standard with a single mini HDMI and a pair of DVI connectors.
The heatsink uses a pair of 80mm fans which blow down on a reasonably large fin array. Unfortunately, this mean that hot air movement is given very little in the way of directionality and much of it ends up with your case.
The back of the card doesn’t hold anything of particular interest but we can see that Gigabyte has simplified the reference PCB while maintain the 4+1 phase power distribution.
Latest Reviews in Featured Reviews
September 16, 2012
Corsair's Vengeance 2000 seems to combine everything a gamer could possibly want in a headset:  virtual 7.1 surround sound capabilities, long distance wireless operation and lightweight construction. ...
September 13, 2012
NVIDIA's new GTX 660 is aimed directly at the highly popular $199 to $249 price bracket.  Equipped with a Kepler-based GK106 core, this new card is meant to go head to head against AMD's HD 7870 while...
September 5, 2012
MSI's GTX 670 Power Edition OC has an enviable rap sheet:  it's performance nearly matches a GTX 680, there's a long feature list and the included Twin Frozr IV heatsink is cool and extremely quiet.  ...
