Review Contents:
Noctua NF-P12 120mm Fan Review
by Michael "SKYMTL" Hoenig     |     December 24, 2007
Packaging and Accessories
Noctua packages their NF-P12 in windowed box which which carries their corporate colors. The front of the box holds a window so you can better see the fan itself along with a short listing of some of the main technical features.
Meanwhile, the back of the box breaks down the technologies Noctua implemented into this fan and describes them all in detail. All of the specifications are also there for you to take a look at but most of these things you will never see if you are buying this online. Nonetheless, it really is a nice box for a fan….
The fan and all of the accessories are neatly coccooned in a clear plastic package in order to hold everything in place. You can also see that there are quite a few accessories which we are about to look at…
Other than the fan itself you get the Ultra Low Noise Adaptor (or U.L.N.A as Noctua calls it), the Low Noise Adaptor (L.N.A), a Molex to 3-pin adaptor, 4 mounting screws and 4 rubber fan mounts. Even though it is one of the more expensive 120mm fans on the market, the Noctua NF-P12 does include a whole lot for your money.
The LNA and ULNA are basically adaptors with different strength resistors built into their wires which bring down the fan from 1300RPM to 1100 and 900 respectively. I find these actually work quite a bit better than Antec’s TriCool concept since they attach directly to the 3-pin connector on the fan and you won’t have a switch hanging around your case.
The rubber fan mounts are perfect for applications where you want to install this fan against metal (like in a case) where vibration could be a problem. They install very easily where they can be pulled through a mounting hole to provide a buffer between the plastic of the NF-P12 and the metal of an enclosure.
Latest Reviews in Cooling
March 15, 2010
When it comes to CPU coolers, most consumers usually have to choose between a low price or good performance since there are very few products on the market that feature both.  With their Traquillo, Ge...
January 28, 2010
When we last looked at Zalman's new CNPS10X family with the Extreme version, there seemed to be a lot to like but there were some shortcomings as well.  Zalman has now launched the Flex Edition which ...
January 5, 2010
At the upcoming CES 2010 show, Zalman will be showing a number of their new products which include cases, coolers and even some new 3D products. In this article, we take a quick, pictorial look at som...
LinkBacks (?)
LinkBack to this Thread: http://www.hardwarecanucks.com/forum/hardware-canucks-reviews/3792-noctua-nf-p12-120mm-fan-review.html
Posted By Date
[BBG Aanschaf] Special: stille allround-pc september 2009 - Complete Systemen & Laptops - GoT March 19, 2010 07:22 AM
Seeking some good quiet 120x120x25 fans - Overclockers Forums February 28, 2010 08:50 AM
How come Noiseblockers are not popular - Page 2 - Overclock.net - Overclocking.net January 29, 2010 03:17 PM
How are the Noctua NF-P12 as radiator fans? - XtremeSystems Forums November 10, 2009 04:02 PM
[Âà]Noctua NF-P12 120mm Fan Review - OCQQ.COM ¹q¸£§ï¸Ë¤Î¤ô§N´²¼ö - ¹q¸£ ¡A´²¼ö¡A¶WÀW·¥­­ ¡A¦w¸Ë¡A±Ð¾Ç¡A°Q½× ¡A·s»D ¡A¤U¸ü¡A·~¬É®ø®§ August 22, 2009 07:05 AM
GameSpot Forums - PC Hardware Discussion - What CPU Cooler Do You Recommend? July 28, 2009 07:35 AM
NCIX FORUMS - Will this fan be quiet when running at a... - Scythe Ultra Kaze 120MM High Static Pres... July 11, 2009 02:50 PM
èͷӥ¼Ò×å - ´ÙÏú¹ã³¡ - ¹ãÎ÷ITȦ - Powered by Discuz! July 9, 2009 12:04 AM
NCIX FORUMS - Noctua NF-P12 review Hardware Canuks.. T... - Noctua NF-P12-1300 120MM Ultra Quiet Coo... June 27, 2009 07:51 PM
XS Fan Review - Part 2 - Page 2 - XtremeSystems Forums June 25, 2009 01:57 AM
Stock fans antec p182 - Cooling - GoT June 8, 2009 02:26 AM
Seeking some good quiet 120x120x25 fans - Overclockers Forums June 4, 2009 12:58 AM
***PHINIX CUBE*** - 2nd June - FINAL update tomorrow ... - Page 6 - bit-tech.net Forums June 3, 2009 02:21 PM
Noctua NF-P12 120mm Fan Review on Air & Water Cooling Review June 2, 2009 01:07 PM
????????? ??? ??????? ?????????? 12cm - ADSLgr.com May 20, 2009 11:56 AM
Noctua NF-P12 (120mm x 120mm x 25mm Fan - 92.3 m³/h at 19.8 dBA) : somuchMORE.biz May 4, 2009 12:03 PM
fan options? - Overclockers UK Forums April 28, 2009 04:26 AM
silentpcreview.com | View topic - Scythe Minebea... Do you advice Low or Mid? April 24, 2009 01:57 AM
Noctua NF-P12 Fan Review on Water & Air Cooling - XtremeSystems Forums April 14, 2009 07:49 AM
Heatsink Fan Selection - Core system - Desktops April 13, 2009 11:50 AM
silentpcreview.com | View topic - Noctua NF-P12 ... vs ten other fans. Done. April 8, 2009 09:07 AM
Noctua.at - sound-optimised premium components April 4, 2009 07:13 PM
