Quantcast
Gigabyte Geforce GTX 470 Super Overclock Review
Author: Michael "SKYMTL" Hoenig
Date: September 22, 2010
Product Name: Gigabyte Geforce GTX 470 Super Overclock
Share |
Ultra Durable VGA Under the Microscope
Gigabyte’s Ultra Durable VGA has been used for quite a while now and it involves a number of high-quality component choices which are made to increase efficiency, decrease temperatures and even have a positive effect on the overclocking potential of a GPU. Having a Gigabyte UDV card means that you are guaranteed the best possible component choices rather than bargain-basement components that some manufacturers use to cut costs.
(From Gigabyte)
2 oz Copper PCB
2 oz copper PCB board doubles the copper inner layer of PCB board and provides unrivaled performance compared with traditional 1 oz PCB board.
Tier 1 Samsung and Hynix Memory
Ultra Durable VGA promises 1st tier Samsung/Hynix memory built with 100% fully testing.
Japanese Solid Capacity
Solid capacitors contain a solid organic polymer, while electrolytic capacitors use a common liquid electrolyte. Our cards use Japanese solid capacitors made by leading Japanese manufactures and offer better electronic conductivity for unrivaled performance.
Ferrite Core (Met ) Chokes
Ferrite core chokes are comprised of a compound of iron-oxide whose properties hold energymuch longer than common iron-core chokes at high frequency. They are able to store energy longer and prevent rapid energy loss at high frequency.
Low RDS (on) MOSFET
Lower RDS (on) MOSFETs are specially designed to produce lower switching resistance for faster electric current charging and discharging.
Latest Reviews in Video Cards
November 15, 2018
The AMD Radeon RX590 is a "new" GPU that's based on old technology. But our performance benchmarks may tell a different story when the RX590 is compared against the RX580 and GTX 1060 6GB....
October 15, 2018
The RTX 2070 launch is upon us and this time we have the $500 ASUS RTX 2070 Turbo and $550 EVGA RTX 2080 XC to check out....
September 18, 2018
The NVIDIA RTX 2080 and RTX 2080 Ti's promise to be two of the fastest graphics cards ever produced. Let's see if our suite of performance benchmarks backs up that claim....
