| by Michael "SKYMTL" Hoenig | December 10, 2007 | ||
| Overclocking…how far can it go? Overclocking…how far can it go? The XFX 8800GTS 512MB is clocked at the Nvidia reference speeds so there should be a bit of headroom for both the memory and the core. Since the memory is rated at 2.0Ghz, I am hoping this will overclock exceptionally well past its current speed of 1940Mhz. Let’s see if this holds true: Max Overclock Speeds Core: 820Mhz Memory: 2234Mhz (DDR) One thing is for sure: these 65nm G92 cores can overclock like the no one’s business. These overclocks represent what was done on the standard heatsink and represent a 170Mhz overclock on the core and a 290Mhz overclock on the memory (or 21% and 13% respectively for those keeping track at home). I was a bit disappointed at a 13% memory overclock but considering the Qimonda GDDR3 modules are rated at 2000Mhz, I guess this was to be expected. So, let’s see how these overclocks perform…. Performance Tests 3DMark06 Professional ![]() ![]() With the bump in clock speeds, the XFX 8800GTS 512MB really kicks the competition in the teeth. I wouldn’t be surprised to see 3DMark world records start falling in short order with these cards in SLI. Crysis ![]() ![]() Crysis sees a massive performance improvement at 1600x1200 resolution without AA enabled but everything still falls to pieces once again when AA is enabled. I actually had to test the results achieved without AA turned on over and over again because I couldn’t believe my eyes… World in Conflict ![]() ![]() Once again we see some huge performance improvements when the Alpha Dog is overclocked. It out muscles the 8800GTX for top honors in this test as well. | ||
