Conclusion
Conclusion
After testing six different GTS 450 cards (the rest of the reviews will be up shortly), we can say without a doubt that ASUS’ TOP DirectCU edition stands out from the competition. It still carries some of the not-so-perfect performance deficiencies of the reference GTS 450 but it has been engineered and pre-overclocked in such a way that issues have been neatly swept under the rug.
The allure of the TOP begins with its beastly heatsink, making it the coolest running GTS 450 tested for our launch-day articles regardless of its high clock speeds. Speaking of frequencies, with a 925Mhz GPU core clock ASUS has one upped the likes of EVGA’s FTW edition, but the latter still has the performance advantage due to 100Mhz higher memory clocks. Overall though, the TOP's performance increase puts it above the HD 5770 in many cases and allows this ASUS model to simply blow the reference card out of the water.
In addition to the sky high speeds and custom heatsink, ASUS basically went back to the drawing board and has completely redesigned every aspect of the GTS 450’s PCB to suit their needs. Granted, this does add to the overall length of the card but it also means a heavily upgraded component selection that just begs for higher overclocks. If you want more all that’s needed is a quick voltage increase in ASUS’ SmartDoctor software and the TOP will be more than happy to oblige.
The crowning achievement of the ASUS GTS 450 TOP DirectCU is its price. At $139 its feature set puts the $149 EVGA FTW to shame and its performance isn’t that far off from some of the highest clocked GF106-based products on the market. This card is near-perfect and shines a positive light upon the entire NVIDIA GTS 450 lineup. As such, it wins our Dam Good and Dam Good Value awards.
Pros:
- Excellent performance
- Price versus competition
- High performance heatsink
- Heavily upgraded components
- Quiet
Cons:
- Slightly elevated power consumption
