Cooler Master Hydra 8800 Hybrid GPU Cooler Review
by Misoprostol     |     December 5, 2007
Installation & Instructions
Now that we're done picking apart every fine detail of the Hydra 8800, it's time to install it on our test video card; an eVGA 8800 GTX Superclocked. We've pre-removed the stock heatsink and we won't show you that process since there are already many guides available on the internet that include the removal of the stock 8800 heatsink.
Cooler Master's instructions made this very simple, but the process was also fairly easy to do because once you've removed the reference heatsink, you know how to install the new one. As discussed before, that is exactly what the Hydra is: a stock heatsink with a few bits added on.
First we applied the included thermal compound (which appears to be the same compound present on the reference design) in the middle of the GPU. Then, being sure not to miss any of them we applied thermal transfer pads to all 4 VRM banks, and all 12 memory modules.
Now the card is ready for us to install our new cooler. Being careful to line up the hole spacing so that the thermal pads don't shift, place the Hydra 8800 on top of the card, then flip the whole thing over to attach them together.
Cooler Master recommends using little black isolators to ensure that no electricity is conducted between the PCB of the card, and the screws. We put each screw in a little bit, then went around and tightened them all individually. Overall, installation went by without a hitch.
And here is the finished result:
Latest Reviews in Cooling
October 12, 2011
September 29, 2011
July 14, 2011
