Conclusion
Conclusion
Somehow Gigabyte has always been able to impress us with their Super Overclock series of cards so there is no denying the fact that we had high expectations for this one. The HD 5770 SoC proved itself to be an extremely competent card but in our opinion, it completely failed to live up to the tradition of its forebearers.
Traditionally, Gigabyte reserves their highest-binned chips and largest clock speed increases for the Super Overclock products but in this case we are left with what amounts to standard OC-edition specifications wrapped up into a pretty package. Sure, the fan is quiet, the components have been beefed up and the packaging cries for attention but under this marketing smoke screen lies a card that should have been much, much more. A mere 50Mhz overclock is simply a slap in the face for everyone’s long-standing expectations of Gigabyte’s flagship series.
In the end you are left paying for upgraded components and a better than reference heatsink; both of which are absolutely pointless on this type of card. The upgraded components could in theory help you increase overclocks but Gigabyte’s OC Guru software stops you cold at 930Mhz anyways. This also makes any voltage adjustments superfluous at best. With such a low factory overclock and very little headroom to further increase speeds, the extensive heatsink goes to complete waste as well. We would go so far as to say it takes a step back from the reference cooler since it lacks the ability to exhaust heat outside of your case and really doesn’t provide a meaningful decrease in temperatures or noise. So here we have a card with a ton of excellent features but it just doesn’t give the end user an opportunity to USE any of them.
We are likely being a bit harsh on this card and on the positive side it doesn't cost all that much more than a reference HD 5770. Its performance per watt ratio is also praiseworthy. However, an average cost of $180 puts it far, far to close to the GTX 460 768MB which pretty much dominates the SoC in nearly every single test.
The HD 5770 SoC is not a bad card in any way, shape or form. Rather, it is a perfectly good card that doesn’t have any business wearing the Super Overclock badge. If marketing begins diluting what was once a name synonymous with high performance, Gigabyte will have a hard time setting their cards apart from those of the competition. Let's hope this trend doesn't continue.
Pros:
- Good performance at most resolutions
- Great performance per watt ratio
- Runs quiet and cool
Cons:
- Paltry overclock which has no business in the SoC series
- Software caps overclocking
- Dominated by the $20 more expensive GTX 460
- Needlessly massive heatsink
