Uniformity / Viewing Angles / Power Consumption
Even with the backlight turned up to 12 (which is actually more than I was comfortable using on a regular basis), the LN55C650 showed a uniformity that was simply second to none. The picture above may look like I took a photo of nothingness but the TV really is on as evidenced by the pause symbol in the bottom corner. Honestly, it doesn’t get any better than this.
Viewing angles were unfortunately a bit of a mixed bag with the picture becoming progressively more washed out as the viewing position moved past 30 degrees off center. This is perfectly fine if you have a four-place couch directly in front of the TV but if you happen to have a group over to watch the game, some will be treated to a less than optimal viewing experience.
I had been told time and again that the backlight setting on an LCD TV can have a significant impact on power consumption but what no one was able to tell me was just how much. So, in order to find out, I pulled out my trusty UPM power meter and Tripp Lite 1800W line conditioner. Basically, the line conditioner was plugged into the wall in ensure the input voltage to the TV was regulated at a constant 121V so any fluctuations would not impact the results. The UPM power meter was then plugged into the line conditioner and the TV was finally attached to the meter. In order to keep these results constant, the opening 15 minutes of I Am Legend were played to get a good cross-section of power consumption figures. Only the peak rates were recorded.
In addition, I measured the Standby and Absolute Max power consumption as well. The Standby value you see is a constant reading instead of a Peak as all of the others. On the other hand, the Absolute Max figure you see is the result of a weekend of regular TV and movie watching while the power meter logged the maximum power consumption. It represents the highest peak power consumption this HDTV pulled from the wall with the blacklight set to 10 after about 8 hours of viewing. For all these tests, the Energy Saver was disabled.
Since the LN55C650 offers double the number of backlight levels than its predecessor which gives you excellent control over not only how your TV looks but also how much power consumes. When push comes to shove though, this new HDTV is roughly as efficient as the B-series set we tested some time ago. What gives the C-650 an edge though is its backlight is actually much brighter than that of the B650 at the lower levels.
Uniformity
Viewing Angles
Power Consumption
