Quantcast
Prolimatech Samuel 17 Small Form Factor CPU Cooler Review
Author: AkG
Date: August 12, 2010
Product Name: Prolimatech Samuel 17 Small Form Factor CPU Cooler
Share |
A Closer Look at the Samuel 17
As you can see the colour combination is classic Prolimatech blue and white but this time the box itself is ultra small as is befitting of this heatsink’s size.
Opening the box up we can see Prolimatech has opted for a two piece, form fitting, high density foam protection scheme. The Samuel 17 is nestled in between these foam protective layers making for one heck a trauma shield.
The list of accessories includes a small syringe of TIM, an installation pamphlet and mounting hardware for Intel 775, 1156, 1366 systems and AMD systems. We really like seeing AMD equipment included and feel it should be standard for all coolers. As you can also see, there is no included fan nor are there any backplates provided due to this heatsink’s paltry weight.
With official dimensions of 121.2mm x 120mm x 45mm we knew the Samuel was going to be tiny but from a visual perspective it is actually smaller than its dimensions lead you to believe. The maximum width is a good 40mm wider than the heatsink itself simply because Prolimatech decided to use two extension arms for 120mm fan compatibility.
Since this is a down draft cooler, the upside to making its footprint actually larger than the fin array is that a certain amount of the fan’s air movement can be used to cool the motherboard’s passive heatsinks. This should prove to be a huge benefit for the integrated graphics chips seen in many HTPCs which need all the cooling help they can get.
While this cooler is small it is not as light as you would think something as small as it “should” weigh. Prolimatech spared no expense here and the Samuel 17 made out of high grade metal without any hints of cheap plastic anywhere.
Latest Reviews in Cooling
January 11, 2018
CORSAIR has introduced their most powerful power supply yet and some new additions to their always popular line of Hydro Series liquid CPU coolers....
May 10, 2017
All in one water CPU coolers are everywhere these days but Fractal Design's new Celsius S36 dares to do things differently. At 360mm, it may be long but its price to performance is incredible....
August 11, 2016
Prebuilt AIO or a potentially complicated custom loop? Alphacool believes we shouldn't have to choose and their Eisbaer 240 combines both under one roof and could blaze a new trail....
