| by Michael "SKYMTL" Hoenig | November 28, 2007 | ||
| Performance Tests Performance Tests Processor: Intel Core 2 Quad Q6600 @ 3.5Ghz (B3) Memory: 4GB Corsair Dominator DDR3 @ 1600Mhz (Thanks to Corsair) Motherboard: Asus Blitz Extreme Graphics Cards: 2X Gigabyte HD2900XT 512MB Disk Drive: Pioneer DVD Writer Hard Drive: Seagate Barracuda 320GB SATAII Fans: 5X Yate Loon 120mm @ 1200RPM Monitor: LG Flatron L2000CN-BF (1600X1200) For our complete power supply testing methodology, please go here: Hardware Canucks Power Supply Testing Methodology Efficiency Testing ![]() Throughout the tests, the Cooler Master Real Power Pro 750W was extremely efficient when compared to some of the higher-priced competition. This is a very good start to our testing regimen, even though efficiency did drop at higher outputs. Voltage Regulation Testing +5V Voltage Regulation ![]() The readings I got from the +5V rail were very interesting considering they gradually increased as the load ramped up. Thankfully, the readings never went above the ATX specification. +3.3V Voltage Regulation ![]() Here we see that the voltage regulation is absolutely superb. So far, this power supply has some of the best +3.3V regulation I have seen in power supplies at or above 700W. +12V Voltage Regulation ![]() Good +12V rail regulation is a must on all modern power supplies and the RPP 750W does quite well in this test though it begins to show that it is straining a bit during the system stress test. Personally, I would never put this kind of stress on a 750W power supply in the first place but it goes to prove that this Cooler Master can handle extreme loads quite well. +12V Ripple ![]() Here is where I was expecting this power supply to stumble a bit but lo and behold, it performed very well. Ripple says far below ATX specified norms throughout every test. Well done!! | ||
| Latest Reviews in Power Supplies | |||||||||
