| by AkG | July 22, 2010 | ||
| Crystal DiskMark Crystal DiskMarkCrystal DiskMark is designed to quickly test the performance of your hard drives. Currently, the program allows to measure sequential and random read/write speeds; and allows you to set the number of tests iterations to run. We left the number of tests at 5. When all 5 tests for a given section were run Crystal DiskMark then averages out all 5 numbers to give a result for that section. Read Performance![]() We’re once again seeing the Mercury in-line with a first generation, pre-mass market firmware drive: the Corsair F100. This was pretty much expected but we would have liked to have seen at least some difference in performance with the latest firmware. Write Performance![]() Here we’re seeing performance that is in-line with other SandForce drives and it’s actually able to narrowly beat out the excellent G.Skill Phoenix in a two of the tests. Not bad at all. | ||
