raxen
Hardware Canucks Reviewer
Processor Unlocking and Overclocking
Core Unlocking – Simply Easy
With “Core Unlock” prominently advertised as one of the Crosshair IV’s features, and coupled with the dedicated “Core Unlocker” button situated on the motherboard itself, it would be an embarrassment if the board did not support unlocking.
Just as expected, our AMD Phenom II X2 555BE processor went from a dual-core to a quad-core processor with a push of the “Core Unlocker” button. Core unlocking can be enabled in BIOS as well where you can select which of the two disabled cores that you would like to unlock. This feature is particularly useful for users with X2 processors that only have one unlockable core.
Processor Overclocking
For those readers who jumped straight to this section looking for the good stuff, you’re in for a treat. The ASUS Crosshair IV Formula is a motherboard geared towards gamers and overclockers so it naturally has several built-in functions that make overclocking a simple breeze.
"OC Button” – The Simplest Way to Boost System Performance
First on the list, we take a look at the built-in “OC Button” that is located on the motherboard itself. To test this overclocking function, we reset the BIOS to default settings and turned off the computer and then simply pushed the appropriate button and turned on the computer. By doing this, the Crosshair will automatically work its magic by increasing the CPU bus speed until it detects instability in the system. Afterwards, the settings are saved in BIOS and the system will boot to an overclocked state.
Overclocking using the “OC Button” literally takes less than a minute. The result is a very respectable 232MHz CPU bus frequency, taking the processor to 3.71GHz without any voltage increases.
In terms of shortcomings, we have to say that the “OC Button” is quite rudimentary since it will not increase any system voltages. As a result, your overclock is limited to whatever tested stable at the stock voltages. In addition, it automatically defaults to an extremely conservative ram divider and timings which resulted in our memory (which is capable of running at 1600MHz) being downclocked to 928MHz at 6-6-6-18 timings.
