| by 3oh6 | November 20, 2007 | ||
| Memory Installation & Test Setup Memory Installation & Test Setup: The opening arguments have been heard in their entirety and we will now hear from the prosecutors witnesses. The prosecutor calls "the ease of installation" to the stand. ![]() When looking at the modules a little earlier, it was noted that installation would not be an issue and as the images show above, that statement was 100% true. The XTC heatspreaders really do not add any kind of bulk to the modules at all. It goes without saying, that any motherboard/CPU cooler combo that will fit standard memory modules, will have no problem with this OCZ Platinum memory. ![]() Either way, upon booting with BIOS defaults set, the memory registers in at 667MHz with 7-7-7-20 2T timings on the 1:2 ratio using a 1333FSB E6850. Obviously manual adjustments are going to be required to get this memory running at even the rated frequencies. This is one of the major drawbacks of high-performance DDR3 memory, overclocking the system bus is required to get the memory to run at full speed because of the highest FSB:RAM ratio being only 1:2. This means that the memory runs at twice the frequency of the FSB so a 1333FSB (333MHz) processor like the E6850 can only run the memory at the fastest frequency of 667MHz (DDR3-1333) without increasing the FSB. As a result, to run DDR3-1600, the FSB has to be running at 400MHz at a minimum. Obviously with 1600FSB (400MHz) CPUs just around the corner, this issue will disappear for users running these processors because the system FSB will be defaulting at 400MHz providing the ability to run the memory at 800MHz (DDR3-1600) without having to overclock anything. ![]()
The only other piece of information worth noting is the use of additional fans. It is the popular belief of many that any and all memory should have some sort of active cooling to remove the heat being generated to not only aid in overclocking but to help keep the memory at safe operating temperatures for a long and healthy life. Heatspreaders aid in removing heat from the ICs but that heat still has to go somewhere and that is where active cooling steps in. At all times during this review, the memory was actively cooled with a 120mm fan overhead. We can now finally get to the best part of memory...overclocking. ![]() | ||
| Latest Reviews in RAM | |||||||||
