| | | Author: AkG Date: June 23, 2010 Product Name: G.Skill Phoenix 100GB Solid State Drive | | | Real World Data Transfers Real World Data Transfers No matter how good a synthetic benchmark like IOMeter or PCMark is, it can not really tell you how your hard drive will perform in “real world” situations. All of us here at Hardware Canucks strive to give you the best, most complete picture of a review item’s true capabilities and to this end we will be running timed data transfers to give you a general idea of how its performance relates to real life use. To help replicate worse case scenarios we will transfer a 4.00GB contiguous RAR file and a folder containing 49 subfolders with a total 2108 files varying in length from 20mb to 1kb (1.00 GB total).
Testing will include transfer to and transferring from the devices, timing each process individually to provide an approximate Read and Write performance. To then stress the dive even more we will then make a copy of the large file to another portion of the same drive and then repeat the process with the small one. This will test the drive to its limits as it will be reading and writing simultaneously. Here is what we found.
It certainly will be interesting to see as time goes by if the Phoenix can continue to be such a dominating force. All we can say is that there is indeed a difference between the Vertex 2 and the Phoenix and it is not what you would expect if you only heard the marketing spin. This drive is always just as fast as the Vertex 2 and in the rare instance faster. It really is heartening to see a company overcome such steep odds to pull off a win like this as the Vertex 2 is no slouch and really is a great drive in and of itself.
