G.Skill Phoenix 100GB Solid State Drive Review
Author: AkG
Date: June 23, 2010
Product Name: G.Skill Phoenix 100GB Solid State Drive
Share |
Random Access Time
To obtain the absolute, most accurate Random access time, h2benchw was used for this benchmark. This benchmark tests how quickly different areas of the drive’s memory can be accessed. A low number means that the drive space can be accessed quickly while a high number means that more time is taken trying to access different parts of the drive. To run this program, one must use a DOS prompt and tell it what sections of the test to run. While one could use “h2benchw 1 -english -s -tt "harddisk test" -w test” for example and just run the seek tests, we took the more complete approach and ran the full gamout of tests and then extracted the necessary information from the text file. This is the command line argument we used “h2benchw 1 -a -! -tt "harddisk drivetest" -w drivetest”. This tells the program to write all results in english, save them in drivetest txt file, do write and read tests and do it all on drive 1 (or the second drive found, with 0 being the OS drive).
It appears that a SandForce drive is a SandForce drive when it comes to random access times regardless of any modifications made to the NAND. Of course, the fact that the Phoenix can keep up with both a drive running earlier “full speed” firmware and the Vertex 2 with its custom firmware is nonetheless impressive.
ATTO Disk Benchmark
The ATTO disk benchmark tests the drives read and write speeds using gradually larger size files. For these tests, the ATTO program was set to run from its smallest to largest value (.5KB to 8192KB) and the total length was set to 256MB. The test program then spits out an extrapolated performance figure in megabytes per second.
Read
While on the surface the Phoenix, F100 and Vertex 2 all have the same read power curve, looks can be deceiving. The Phoenix at what amounts to almost every file size is slightly faster than the other SandForce drives. Big files, little files, the Phoenix really does do a slightly better job at reading them.
Write
Except for one or two minor blips the Phoenix is once again just as fast as the Vertex 2, if not just a little bit faster here and there. It really does seem that G.Skill have come up with the answer to the SandForce firmware conundrum. Hopefully, other companies will follow suit and simply use higher grade NAND rather than giving into SandForce intentionally gimping their drives.
Latest Reviews in Storage
February 6, 2012
We've been hearing about and anticipating new Intel's Cherryville SSDs for some time now they are finally being released in the guise of the 520 series.  They are built around the same SandForce SF228...
January 23, 2012
Seagate's new Barracuda 3TB is one of the fastest hard drives currently available and it come with plenty of storage space for a reasonable price.   What it can't do is compete on a level performance ...
January 12, 2012
Corsair's Performance 3 256GB SSD showed many enthusiasts that an SSD didn’t need to have “SandForce” in the same sentence as “performance” and that the new Marvell controller was a force to be reckon...
