Quantcast
Thermaltake Frio CPU Cooler Review
Author: AkG
Date: July 19, 2010
Product Name: Thermaltake Frio CPU Cooler
Share |
Dual Fan Performance Results
As expected the Frio is a beast when you run both of its fans at full speed. However, in testament to exactly how good these fans are, the difference between single fan results and dual fan results is only a little more than 3.5°C. Also as expected, when comparing “apples to apples” with dual NF-P12-1300 fans the Thermaltake Frio has a firm grasp on third place. This is impressive considering its price.
Sound Level Testing
While everyone "hears" noise differently there is one easy way to remove all subjectivness and easily compare different fans: use a sound level meter. This way you can easily compare the various fans noise envelopes without us colouring the results and see what fans fit within your personal comfort level. Of course, we will endeavour to try and explain the various results (which are taken at a 30 inch distance) to help you our readers get an even better understanding of how loud a cooler's stock fan is, but even if you discount our personal opinions, the fact remains numbers don't lie. All fans are tested with both voltage regulation / PWM turned off.
All in all this fan really is versatile. At full speed it is loud, but then again it is going awfully damn fast and it offers very good performance for the amount of noise it makes. More importantly, it basically has a very similar sound profile to that of a Scythe S-Flex G when running at G speeds (yet gives better results) and it out and out blows away Noctua when running at the same speed as our NF-P12-1300 does.
Latest Reviews in Cooling
January 11, 2018
CORSAIR has introduced their most powerful power supply yet and some new additions to their always popular line of Hydro Series liquid CPU coolers....
May 10, 2017
All in one water CPU coolers are everywhere these days but Fractal Design's new Celsius S36 dares to do things differently. At 360mm, it may be long but its price to performance is incredible....
August 11, 2016
Prebuilt AIO or a potentially complicated custom loop? Alphacool believes we shouldn't have to choose and their Eisbaer 240 combines both under one roof and could blaze a new trail....
