Review Contents:
Binaura A102AB Home theater System Review
by Robscix     |     November 11, 2007
Long Term Testing
I have had this system near two weeks and I use it for every DVD I watch. The system never fails to impress me and my guests which I eagerly audition the system for. I have noticed it is a careful line when setting up the bass impact of this system and overall volume. It is easy to add a hard bass edge to dialog which I prefer to be clear and concise. The system easily blended into our living room and has become a part of the home theater.
Modding Options
This system is very well built and included red Loctite on all internal screws. This compound is very hard to remove from screws for modding. You could improve the capacitors with audio grade black gates. Using shielding medium to isolate the various sections may improve sound quality to some extent. You may be able to modify the output section by adding better filtering capacitors. This system would NOT be easy to mod and I don’t recommend it as you will void your warranty and possibly destroy the unit if your inexperienced.
Latest Reviews in Audio
February 15, 2009
The world of high-end headphones isn't as crowded as some might think but when there is a new competitor on the scene, people tend to stand up and take notice. Today we will be looking at the Beats b...
December 24, 2008
Back in November we brought you a sneak peak at the upcoming and highly anticipated ASUS Xonar Essence SXT. Today we expand upon that preview with another look at this card but this time we have driv...
November 12, 2008
ASUS will soon be launching their new Essence STX soundcard which is geared toward headphone and audio enthusiasts in general. We have received an exclusive sneak peak and hands-on session with the c...
LinkBacks (?)
LinkBack to this Thread: http://www.hardwarecanucks.com/forum/hardware-canucks-reviews/3225-binaura-a102ab-home-theater-system-review.html
Posted By Date
Binaura B102AB Home Theater System October 22, 2009 02:26 AM
Binaura B102AB Home Theater System - PCStats.com August 9, 2009 04:47 PM
Techgage - Tech News From Around The Web May 5, 2009 09:01 PM
