Antec Neopower 650W Blue Power Supply Review
by Michael "SKYMTL" Hoenig     |     October 19, 2007
+12V AC Ripple Testing
This is a very significant test in the fact that AC Ripple can be the cause of many common computer problems. Short term effects of excess ripple can be anything from an unstable overclock to memory errors while long term effects can include premature component failure and decreased component performance. The ATX v2.01 ripple tolerance is anything below 120mV on the +12V rail.
To test for ripple the following tests were run twice for 30 minutes while the ripple was being measured by the Singray o-scope. The values were the highest peak ripple measurement across all of the +12V rails. So, if the +12V1 rail shows a ripple of 20mV and the +12V2 rail shows a ripple of 40mV, the highest value will be graphed.
The “Idle” value was done with an overclocked processor and the graphics card at stock speeds while running the Windows Desktop.
The “Load” value was done with an overclocked processor and the graphics card at stock speeds while running Company of Heroes.
The “Load (OC)” value was done with an overclocked processor and a heavily overclocked (both 2D and 3D overclocked to the same value) graphics card. Company of Heroes was played while Orthos was running on the processor in the background.
The “Load (SLI)” value was run with 2 8800GTS cards in SLI running at stock speeds with the processor overclocked to 2.6Ghz. Company of Heroes was then run to determine load values.
The “Load SLI OC” test was run with 2 overclocked 8800GTS cards (650/1800) in SLI while playing Company of Heroes for 30 minutes. At the same time, Orthos was running in the background to put stress on the processor (OC’d to 2.6Ghz) while a DVD was burned and HDtach was running a hard drive scan.
The Antec Neopower Blue 650W finished out tests flying high with very minimal ripple on the +12V rails through even the most stressful test. This power supply follows in the footsteps of past Seasonic-built power supplies we have tested and excels in this test.
Heat and noise
No matter how well a power supply performs in the performance tests, if it is loud enough to drive someone insane it won’t do much good. I am happy to report that according to my very subjective tests, the Neopower 650W is extremely quiet even at the highest loads I put it under. The fan spun lazily around while keeping the interior at a relatively cool temperature even after the 1 hour SLI OC test.
