| by Michael "SKYMTL" Hoenig | October 19, 2007 | ||
| Output Characteristics Output Characteristics Everything looks really good in the output department with the Neopower 650W being able to deliver nearly all of its power through the all-important +12V rails. The 19A (228W) available on each +12V rail is sufficient to power nearly any hardware combination you might have but there is no indication of which +12V rail is responsible for what. Upon first glance it looks like the PCI-E 8-pin would be on its own virtual “rail” with a 19A OCP circuit while the second PCI-E connector is on the same virtual rail as the SATA and Molex connectors. Finally, the CPU connector is on its own separate “rail” as well. I can’t test this theory since I have no way of loading 19A on a single rail but if the Neopower is not set up like this, I have my money on the possibility it is set up like the HX620 which means it is a single rail unit. PERFORMANCE TESTS Instruments Used: Belkin 1100VA UPS Rexus PSU tester Fluke 187 Digital Multimeter UPM Power Meter USB Instruments Stingray USB O-Scope USB Instruments Differential oscilloscope probe Test Platform: DFI Lanparty SLI-DR Expert AMD X2 3800+ (at 2.6Ghz) 2GB Corsair PC4000 Ram (at 520Mhz) EVGA 8800GTS (Stock, OC 650/1900, SLI, SLI OC 650/1800) 1x Samsung Spinpoint 250GB SATA Hard drive Gigabyte 3D Aurora 570 Case Pioneer DVD Writer 4X 120mm Noctua NF-S12-1200 fans Important note: Because of processor limitation, 8800GTS cards in SLI are seriously bottlenecked in Company of Heroes. Thus, while they still drew quite a high amount of power, when coupled with a higher end system or playing at higher resolutions they would probably draw much more. One way or another, I would NOT recommend anything under a good 700W power supply for a pair of 8800GTS cards. These tests are done as benchmarks ONLY. | ||
