Intel Core i7-980X Gulftown Six-Core 32nm Processor Review
by MAC     |     March 10, 2010
Test Setups & Methodology
For this review, we have prepared four different test setups, representing all the popular platforms at the moment, as well as most of the best-selling processors. As much as possible, the four test setups feature identical components, memory timings, drivers, etc. Aside from manually selecting memory frequencies and timings, every option in the BIOS was at its default setting.
Intel Core i7 "Gulftown" Test Setup
Intel Core i7 "Bloomfield" Test Setup
*The 1802 BIOS was only used for the Everest, ScienceMark, and Power Consumption tests.
Intel Core i5 & Core i7 "Lynnfield" Test Setup
Intel Core i5 "Clarkdale" Test Setup
Intel Core 2 Test Setup
AMD Phenom II AM3 Test Setup
For all of the benchmarks, appropriate lengths are taken to ensure an equal comparison through methodical setup, installation, and testing. The following outlines our testing methodology:
A) Windows is installed using a full format.
B) Chipset drivers and accessory hardware drivers (audio, network, GPU) are installed followed by a defragment and a reboot.
C)To ensure consistent results, a few tweaks were applied to Windows Vista and the NVIDIA control panel:
  • Sidebar – Disabled
  • UAC – Disabled
  • System Protection/Restore – Disabled
  • Problem & Error Reporting – Disabled
  • Remote Desktop/Assistance - Disabled
  • Windows Security Center Alerts – Disabled
  • Windows Defender – Disabled
  • Screensaver – Disabled
  • Power Plan - High Performance
  • NVIDIA PhysX – Disabled
  • V-Sync – Off
D) Programs and games are then installed & updated followed by another defragment.
E) Windows updates are then completed installing all available updates followed by a defragment.
F) Benchmarks are each run three times after a clean reboot for every iteration of the benchmark unless otherwise stated, the results are then averaged. If they were any clearly anomalous results, the 3-loop run was repeated. If they remained, we mentioned it in the individual benchmark write-up.
Here is a full list of the applications that we utilized in our benchmarking suite:
  • 3DMark06 Professional v1.1.0
  • 3DMark Vantage Professional Edition v1.0.1
  • Cinebench R10 64-bit
  • Crysis v1.21
  • Far Cry 1.02
  • HyperPi 0.99b
  • High Definition Experience and Performance Ratings Test 2009 (HDxPRT 2009) (Adobe Elements 7.0/QuickTime Player/iTunes 8.0.1/Sorenson Squeeze/PowerDVD 8/DiVX engine)
  • Lame Front-End 1.0
  • Lavalys Everest Ultimate v5.02.1834 Beta (v5.30.1977-2043 Beta for Bloomfield, Clarkdale, Lynnfield, Gulftown)
  • Left 4 Dead
  • PCMark Vantage Advanced 64-Bit Edition (1.0.0.0)
  • Photoshop CS4 Extended (64-bit)
  • ScienceMark 2.0 Build 21MAR05
  • Street Fighter 4 Demo
  • Supreme Commander v1.1.3280
  • Valve Particle Simulation Benchmark
  • WinRAR 3.8.0
  • World in Conflict v1.010
  • x264 HD Benchmark v1.0
That is about all you need to know methodology wise, so let's get to the good stuff!
Latest Reviews in Processors
February 1, 2012
Being the newest and highest-end addition to AMD’s A-series APU lineup, not only does the A8-3870K feature the much raved about integrated Radeon HD 6550D, but it comes with fully unlocked multipliers...
November 14, 2011
Intel's X58 platform has been around for over three years now (yes, it really has been that long) and for many a changing of the guard in the enthusiast market couldn't come soon enough.  Replacing th...
October 11, 2011
After many, many years of gossip, presentations, leaks, and showcases AMD's new Bulldozer processors are finally here. This is AMD's attempt at making an architecture with significant multi-threaded p...
